filter for group elements matching groupname
CADdaddy.com
CADdaddy.com
I want to filter for element IDs of groups matching groupname.  Can anybody help me with this?
James LeVieux
RPTHOMAS108
VB
Public Function Execute_GroupNameFilter(ByVal commandData As Autodesk.Revit.UI.ExternalCommandData, _ ByRef message As String, ByVal elements As Autodesk.Revit.DB.ElementSet) _ As Autodesk.Revit.UI.Result Dim UIDoc As Autodesk.Revit.UI.UIDocument = commandData.Application.ActiveUIDocument If UIDoc Is Nothing Then Return Result.Cancelled Else Dim Doc As Document = UIDoc.Document Dim FEC As New FilteredElementCollector(Doc) Dim ECF1 As New ElementCategoryFilter(BuiltInCategory.OST_IOSDetailGroups) Dim ECF2 As New ElementCategoryFilter(BuiltInCategory.OST_IOSModelGroups) Dim LorF As New LogicalOrFilter(ECF1, ECF2) Dim Els As List(Of ElementId) = FEC.WherePasses(LorF).WhereElementIsNotElementType.ToList. _ FindAll(Function(X) X.Name = "TheGroupIWant").Select(Function(v) v.Id).ToList UIDoc.Selection.SetElementIds(Els) Return Result.Succeeded End Function
C#
public Autodesk.Revit.UI.Result Execute_GroupNameFilter(Autodesk.Revit.UI.ExternalCommandData commandData, ref string message, Autodesk.Revit.DB.ElementSet elements)
		Autodesk.Revit.UI.UIDocument UIDoc = commandData.Application.ActiveUIDocument;
		if (UIDoc == null)
			return Result.Cancelled;
		Document Doc = UIDoc.Document;
		FilteredElementCollector FEC = new FilteredElementCollector(Doc);
		ElementCategoryFilter ECF1 = new ElementCategoryFilter(BuiltInCategory.OST_IOSDetailGroups);
		ElementCategoryFilter ECF2 = new ElementCategoryFilter(BuiltInCategory.OST_IOSModelGroups);
		LogicalOrFilter LorF = new LogicalOrFilter(ECF1, ECF2);
		List<ElementId> Els = FEC.WherePasses(LorF).WhereElementIsNotElementType().ToList().FindAll(X => X.Name == "TheGroupIWant").Select(v => v.Id).ToList();
		UIDoc.Selection.SetElementIds(Els);
		return Result.Succeeded;
JimJia
Thanks for RPTHOMAS108‘s replay, this should works!
Yet another approach is to use shortcut OfClass API of FilteredElementCollector:
			FilteredElementCollector coll = new FilteredElementCollector(this.Document);
			List<ElementId> groupIds = coll.OfClass(typeof(Group))
				.ToList().FindAll(X => X.Name == "<Your group name>").Select(v => v.Id).ToList();
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
abudayev
Hi, I'm trying to do something similar, but I want to create groups of filtered structural connections, however I don't know apriori how many groups will be and their names. any suggestions?
here i collected all structural connections in the view:
connections_in_view = [x for x in DB.FilteredElementCollector(doc, view.Id) if x.Category != None if x.Category.Name == 'Structural Connections']
but what are the further steps? I am stuck.
thanks.
