Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Filter for elements where parameter unequal to string
m.mastbergen
m.mastbergen
I want to get each element that does not yet have "theValue" for a specific parameter. In the following code example i filter for elements that DO have the value, how do i reverse/invert this to get what i need?
FilteredElementCollector fec = new FilteredElementCollector(doc);
var elements = fec.ToElements();
var id = elements[0].LookupParameter("IfcName").Id;
ParameterValueProvider pvp = new ParameterValueProvider(id);
var fsc = new FilterStringEquals();
var ruleValue = "theValue";
var frule = new FilterStringRule(pvp, fsc, ruleValue, false);
var filter = new ElementParameterFilter(frule);
fec = fec.WherePasses(filter);
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @m.mastbergen ,
You can use the FilterInverseRule
https://www.revitapidocs.com/2023/bd21b884-c026-5a16-4470-72172b71db4a.htm
Here is the sample code
https://spiderinnet.typepad.com/blog/2011/07/elementparameterfilter-using-filterinverserule-to-filte...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
