Filter for elements hidden in a view
PaulCollins7972
Message 1 of 8
PaulCollins7972
Hi
Please can someone advise on how to construct a filter that will find elements that have been "hidden by element" in a view?
I have some working code that finds all elements in the current design option and then iterates through each to find which are hidden, but there must be a way to construct an element parameter filter that will be quicker but I can't figure out how to build using the element.ishidden(vw) parameter.
Dim doc As Autodesk.Revit.DB.Document = commandData.Application.ActiveUIDocument.Document
Dim vw As Autodesk.Revit.DB.View = doc.ActiveView
Dim CollectorView As FilteredElementCollector = New FilteredElementCollector(doc)
Dim activeOptId As ElementId = Autodesk.Revit.DB.DesignOption.GetActiveDesignOptionId(doc)
'create an ElementDesignOption filter
Dim Filter_Option As New ElementDesignOptionFilter(activeOptId)
CollectorView.WherePasses(Filter_Option)
Dim Iter_Elements As IEnumerator = CollectorView.GetElementIterator
'iterate through all the elements to find hidden elements
Do While Iter_Elements.MoveNext()
If (Not (Iter_Elements.Current) Is Nothing) Then
Dim e As Element = Iter_Elements.Current
If e.CanBeHidden(vw) Then
If e.Id <> vw.Id Then 'don't include the view border if hidden
If e.IsHidden(vw) Then
Thanks!
Replies (7)
Message 2 of 8
jeremytammik
Does this help?
http://thebuildingcoder.typepad.com/blog/2014/10/is-a-given-element-hidden-in-a-view.html
I hope so!
Please let us know how it goes and how you can make use of ti.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 8
PaulCollins7972
Jeremy
I am writing an add-in that finds all the elements that have been "hidden by element" in the active view.
We have a few user that are prone to hide elements in view and this is a pain to sort out.
My code  scans the model and if anything is found presents a dialog which shows what is hidden and lets the user "unhide" selectively.
The code that I have works ok but iterates over everything in the model to build a list of hidden elements.
I was hoping to use something like this to speed things up as your blog encourages us to filter not iterate over everyting!
Dim Rule1 As FilterRule = New FilterStringRule(pvp, Eval, RuleString, True)
Filter_Param = New ElementParameterFilter(Rule1)
' Create a logic And filter for category and parameter
Dim Filter_Select As LogicalAndFilter = New LogicalAndFilter(Filter_Cat, Filter_Param)
CollectorDoc.WherePasses(Filter_Select).WhereElementIsNotElementType.ToElements()
Iter_Element = CollectorDoc.GetElementIdIterator()
I can't figure out how to get the e.ishidden(viewname) into the above. There doesn't seem to be a built in parameter that I can use.
Sorry don't think your example helps, and I have been looking at your blog (which is great) trying to find some help.
Message 4 of 8
Hi Paul.
Use linq, something like
ICollection<ElementId> collector= new FilteredElementCollector(doc).OfClass(typeof(FamilyInstance)).WhereElementIsNotElementType()
.Where(x =>x.IsHidden(Vy)).
Select(x => x.Id).Cast<ElementId>().ToList();
good Luck!
/Martin
Message 5 of 8
PaulCollins7972
Thanks Martin
That's just what I was looking for.
Paul
Message 6 of 8
Hello Paul,
I am having a look at your code but for some reason I am not being able to run it appropiately. Would it be much to ask if you cold post your solution in this post?
I would really appreciate it as it would be a very useful tool for me.
Thank you.
Luis
Message 7 of 8
PaulCollins7972
Hi Luis
This is what I ended up with. It finds all elements in the active design option and uses LINQ to see if they are hidden by element in the current view.
My code then loads these into a ListView. When the user chooses an item in the list it is temporarily unhidden as a preview, when the dialog is OK'd then all selected elements are unhidden. I had to check for worksets and phases to see if each element should be visible in the current view, view filters still to do!
Dim collector As FilteredElementCollector = New FilteredElementCollector(doc)
collector.WherePasses(Filter_Option)
'create a LINQ query
Dim query = From item As Element In collector Where item.IsHidden(vw) Select item
For Each e As Element In query
Works OK in 2013, 2014 and 2015
Hope that is useful.
Paul
Message 8 of 8
Thank you Paul!
