Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Filter all model elements except symbol elements
2 REPLIES 2
rita.aguiar
1078 Views, 2 Replies
How can I filter all model elements but not also the symbol elements?
I am creating a plugin using the Lab4_2_ExportParametersToExcel from the Revit API .NET Labs.
In Lab4_2_ExportParametersToExcel we are iterating "over all elements, both symbols and model elements, and then in the dictionary." (see attached .png)
How can I get all model elements but not the symbol elements?
The reason why I'm asking this is because when I run this plugin on a project with just a few columns and walls to make a small test, I get an endless list of elements (on an excel file) that I have no idea of where they came from and what they are, so I guess they might be symbol elements. (see excel file)
Any help would be appretiated
  [Transaction(TransactionMode.ReadOnly)]
  public class Lab4_2_ExportParametersToExcel : IExternalCommand
    public Result Execute(ExternalCommandData commandData,
        ref string message, ElementSet elements )
      UIApplication app = commandData.Application;
      Document doc = app.ActiveUIDocument.Document;
      // Extract and group the data from Revit in a dictionary,
      //where the key is the category name and the value is a list of elements.
      Stopwatch sw = Stopwatch.StartNew();
      Dictionary<string, List<Element>> sortedElements
        = new Dictionary<string, List<Element>>();
            // Iterate over all elements, both symbols and
            // model elements, and then in the dictionary.
        ElementFilter f = new LogicalOrFilter(
        new ElementIsElementTypeFilter( false ),
        new ElementIsElementTypeFilter( true ) );
      FilteredElementCollector collector
        = new FilteredElementCollector( doc )
          .WherePasses( f );
2 REPLIES 2
jeremytammik
in reply to: rita.aguiar
The sample you are using is retrieving absolutely all Revit database elements.
It uses a union of two Booleans, one set to true, one to false.
This is not what you are after at all.
I suggest that you read a little bit more about the basics of filtered element collectors and implement your own filter that really does want you need and retrieves the elements you are interested in:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.9
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
so-chong
This might be useful to you as an example how to filter all model elements.
https://github.com/jeremytammik/AdnRevitApiLabsXtra/blob/09c5ef80b6b4730159f4eb2e0a84c64d124bec92/Xt...
If you are new to the Revit API i also recommend you to study how to use filtered element collectors, for your own need as Jeremy mentioned.
Hope this helps,
Cheers,
So-Chong
Rail Community
