File Access Exception
Nathan.HilsonN67V6
Message 1 of 10
Nathan.HilsonN67V6
Running into an issue where the txt file is unable to be accessed but i can still push things to the folder. I have admin rights on everything and pushed admin rights to the application. Not sure if it is code related.
JtWindowHandle:
using System;
using System.Diagnostics;
using System.Windows.Forms;
namespace ScheduleData
    /// <summary>
    /// Wrapper class for converting
    /// IntPtr to IWin32Window.
    /// </summary>
    public class JtWindowHandle : IWin32Window
        IntPtr _hwnd;
        public JtWindowHandle(IntPtr h)
            Debug.Assert(IntPtr.Zero != h,
              "expected non-null window handle");
            _hwnd = h;
        public IntPtr Handle
            get
                return _hwnd;
Command:
#region Namespaces
using System.IO;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using System.Drawing;
using System.ComponentModel;
using System.ComponentModel.DataAnnotations;
using System;
using System.Collections;
using System.Collections.Generic;
using System.Text;
using Autodesk;
using Autodesk.Revit;
using Autodesk.Revit.DB.Structure;
using TpMechanical.TpMechanical.Forms;
using System.Linq.Expressions;
#endregion
    [Transaction(TransactionMode.ReadOnly)]
    public class ScheduleDataCommand : IExternalCommand
        /// <summary>
        /// Define the schedule export folder.
        /// All existing files will be overwritten.
        /// </summary>
        const string _export_folder_name
          = "C:\\tmp\\schedule_data";
        /// <summary>
        /// Schedule export filename extension.
        /// </summary>
        const string _ext = ".txt";
        const string _caption_prefix
          = "Schedule Data - ";
        /// <summary>
        /// Select a text file in the gioven folder.
        /// </summary>
        /// <param name="folder">Initial folder.</param>
        /// <param name="filename">Selected filename on success.</param>
        /// <returns>Return true if a file was successfully selected.</returns>
        static bool FileSelect(
          string folder,
          out string filename)
                folder = Path.GetDirectoryName(folder);
                OpenFileDialog dlg = new OpenFileDialog();
                dlg.Title = "Select Schedule Data File";
                dlg.CheckFileExists = true;
                dlg.CheckPathExists = true;
                //dlg.RestoreDirectory = true;
                dlg.InitialDirectory = folder;
                dlg.Filter = ".txt Files (*.txt)|*.txt";
                bool rc = (DialogResult.OK == dlg.ShowDialog());
                filename = dlg.FileName;
                return rc;
        void DisplayScheduleData(
          string filename,
          IWin32Window owner)
            ScheduleDataParser parser
              = new ScheduleDataParser(filename);
            System.Windows.Forms.Form form
              = new System.Windows.Forms.Form();
            form.Size = new Size(400, 400);
            form.Text = _caption_prefix + parser.Name;
            DataGridView dg = new DataGridView();
            dg.AllowUserToAddRows = false;
            dg.AllowUserToDeleteRows = false;
            dg.AllowUserToOrderColumns = true;
            dg.Dock = System.Windows.Forms.DockStyle.Fill;
            dg.Location = new System.Drawing.Point(0, 0);
            dg.ReadOnly = true;
            dg.TabIndex = 0;
            dg.DataSource = parser.Table;
            dg.Parent = form;
            dg.IsAccessible= true;
            form.ShowDialog(owner);
        public Result Execute(
          ExternalCommandData commandData,
          ref string message,
          ElementSet elements)
                IWin32Window revit_window
                  = new JtWindowHandle(
                    Process.GetCurrentProcess().MainWindowHandle);
                UIApplication uiapp = commandData.Application;
                UIDocument uidoc = uiapp.ActiveUIDocument;
                Document doc = uidoc.Document;
                FilteredElementCollector col
                  = new FilteredElementCollector(doc)
                    .OfClass(typeof(ViewSchedule));
                ViewScheduleExportOptions opt
                  = new ViewScheduleExportOptions();
                    foreach (ViewSchedule vs in col)
                        Directory.CreateDirectory(
                         _export_folder_name);
                        vs.Export(_export_folder_name,
                        vs.Name + _ext, opt);
                string filename;
                while (FileSelect(_export_folder_name,
                  out filename))
                    DisplayScheduleData(filename,
                      revit_window);
                return Result.Succeeded;
DataParse:
using System;
using System.Data;
using System.IO;
using System.Linq;
using System.Text;
    class ScheduleDataParser
        /// <summary>
        /// Default schedule data file field delimiter.
        /// </summary>
        static char[] _tabs = new char[] { '\t' };
        /// <summary>
        /// Strip the quotes around text strings
        /// in the schedule data file.
        /// </summary>
        static char[] _quotes = new char[] { '"' };
        string _name = null;
        DataTable _table = null;
        /// <summary>
        /// Schedule name
        /// </summary>
        public string Name
            get { return _name; }
        /// <summary>
        /// Schedule columns and row data
        /// </summary>
        public DataTable Table
            get { return _table; }
        public ScheduleDataParser(string filename)
            StreamReader stream = File.OpenText(filename);
            string line;
            string[] a;
            while (null != (line = stream.ReadLine()))
                a = line
                  .Split(_tabs)
                  .Select<string, string>(s => s.Trim(_quotes))
                  .ToArray();
                // First line of text file contains
                // schedule name
                if (null == _name)
                    _name = a[0];
                    continue;
                // Second line of text file contains
                // schedule column names
                if (null == _table)
                    _table = new DataTable();
                    foreach (string column_name in a)
                        DataColumn column = new DataColumn();
                        column.DataType = typeof(string);
                        column.ColumnName = column_name;
                        _table.Columns.Add(column);
                    _table.BeginLoadData();
                    continue;
                // Remaining lines define schedula data
                DataRow dr = _table.LoadDataRow(a, true);
            _table.EndLoadData();
Replies (9)
Message 2 of 10
RPTHOMAS108
You are not closing the StreamReader.
Call 'Close' on it and also best to use a using statement, since you can as TextReader implements IDisposable.
Message 3 of 10
Nathan.HilsonN67V6
No luck. Still Getting This error.
Message 4 of 10
RPTHOMAS108
Only a few things I can suggest.
Check the folder is being created
Don't call Directory.Create repeatedly (create it once outside for each loop).
Try inputting path into export function with '\\' at end, some things are more pedantic than Windows in terms of distinguishing directories.
Try creating file manually in that location
It might also be the export function being called repeatedly, these things they hold onto resources, see if ViewSchedule.Dispose helps (although that is a long shot perhaps).
Message 5 of 10
Nathan.HilsonN67V6
Tried them all & still the same issue.
This is where I'm at currently. I moved the directory creation outside of the loop as well.
                            if (vs == null)
                                continue;
                        vs.Dispose();
Message 6 of 10
RPTHOMAS108
Can you also confirm if it is happening on the first iteration of the loop i.e. is anything being created in the folder?
Also how is the view schedule named?
I remember going back a few years I had a similar issue exporting dwgs that had shared images. Revit would hold onto the image so next time it was exported again it wouldn't overwrite.
The only workaround was to create the file in a uniquely named folder and then copy it on elsewhere. Then try to look for and delete the mess left behind the next time the routine was run.
Message 7 of 10
Nathan.HilsonN67V6
Looks like the folder is being created & accessed which makes less sense to me if the resources aren't being held.
I'm using the Revit SDK "Schedule Data" as a starting point & manipulating as needed if that helps as far as troubleshooting.
Message 8 of 10
RPTHOMAS108
Try adding delay between exports to see if it is a latency issue or not.
Message 9 of 10
Nathan.HilsonN67V6
Nope. Is it possible that something is incorrect in the file select method?
        /// <summary>
        /// </summary>
          string folder,
                Title = "Select Schedule Data File",
                CheckFileExists = true,
                CheckPathExists = true,
                RestoreDirectory = true,
                InitialDirectory = folder,
                return rc;
Message 10 of 10
Nathan.HilsonN67V6
Got rid of the loop completely & it worked. You were right about it holding it. Thanks for the help!
