Fan noise when running Revit
Okey, so I have this problem with high fan noise when I'm running Revit. No problem running AutoCad, illustrator, photoshop etc, but as soon as I start working in Revit the fan gets up to full speed within a few minutes. When running a Workload analysis with Dell Precision Optimizer the result is that CPU, Disk and Graphics have an average utilization of 0% with extremely short peaks around 50% and a memory average of 50%. If this Workload Analysis is accurate or not I don't know but this is the recurring result.
My Hardware is a "new" Dell Precision M3800 with i7-4712HQ 2.30 GHz, 16 gb RAM (2x8), Quadro K1100M Graphics Card, SSD disk.
I'm running Revit 2017 on Windows 10 64-bit. All drivers has been updated to the newest versions including BIOS update. Hardware Acceleration is turned on in Revit.
Do you have any ideas on what the "problem" could be or if there is a solution or not?
Is the hardware not good enough? Can it be a settings or drivers issue?
Is there something I can do or do I have to buy a new computer?
Thanks in advance!
JimJia
Dear Marcus,
Revit API forum is for API (Application Programming Interface) questions.
For non-API questions, please choose other forums that is more appropriate. For example,
Installation and licensing:
http://forums.autodesk.com/t5/installation-licensing/bd-p/24
Revit Architecture (including common platform product usage questions):
http://forums.autodesk.com/t5/revit-architecture/bd-p/133
Revit Structure:
http://forums.autodesk.com/t5/revit-structure/bd-p/153
Revit MEP:
http://forums.autodesk.com/t5/revit-mep/bd-p/188
I will also transfer your question to related experts. They will reply you later.
We appreciate your understanding and cooperation.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
