Family Parameters
Family Parameters
psh.t
Family Parameters
psh.t
Hello, Forum-board users! Would you so kind to give me a hint as I'm a bit confused. So, how can I get and change parameters of an active document if this document is a Family itself? If the Family is open in the project I usually do this way:
FilteredElementCollector FamilyS = new FilteredElementCollector(doc)
                                                      .OfClass(typeof(FamilySymbol));
foreach (FamilySymbol FS in FamilyS)
   foreach (Parameter P in FS.Parameters)
      if (P.Definition.Name == "My Parameter")
            //here I'm dealing with the parameter
But if the open document (doc) is the Family, then doc.Parameters doesn't exist. I tried to do next:
FilteredElementCollector ParamElem = new FilteredElementCollector(familyDoc)
                                                         .OfClass(typeof(ParameterElement));
foreach (ParameterElement PE in ParamElem)
      if (PE.Name == "My Parameter")
      //My parameter was got as a result but in PE there's no method for to change it in PE
      foreach (Parameter P in PE.Parameters)
           //My parameter wasn't got
Then I tried to do this:
FamilyManager FM = familyDoc.FamilyManager;
foreach (FamilyParameter FamilyP in FM.Parameters)
    if (FamilyP.Definition.Name =="My Parameter")
       //My parameter was got as a result but in PE there's no method for to change it in FamilyP
     foreach (Parameter P in FamilyP.AssociatedParameters)
Fnd that's all.
Павел Тер-Микаэлян
email: psh.t@inbox.ru
psh.t
I found the answer:
http://thebuildingcoder.typepad.com/blog/2009/11/family-parameter-value.html
Павел Тер-Микаэлян
jeremytammik
Thank you for posting the solution you found.
I marked it as an answer to close this thread.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Dear jeremy Recently
I'm study this article "Family Parameter Value" (including the example code),but compare with the 2017 sample on GitHub have some question as below:
1 Why the "CmdFamilyParamValues.cs" is different in each version?(link 1-1~2)
2 As the Revit API Doc I can't find "get_Elements" method but have "GetElementClass Method". Could you explain why?(link2)
link: 1-1 https://thebuildingcoder.typepad.com/blog/2009/11/family-parameter-value.html
1-2 https://github.com/jeremytammik/the_building_coder_samples/tree/master/BuildingCoder/BuildingCoder
2 https://thebuildingcoder.typepad.com/blog/2009/09/document-elements.html
jeremytammik
Thank you for your questions.
Those are some pretty old posts you are referring to.
1. Things change. In fact, the only constant is change.
2. get_Elements was in fact auto-generated from the `Elements` property. Since it takes an argument, unlike a 'normal' property.
The `Elements` property was replaced by filtered element collectors almost ten years ago.
The most common way (almost the only way) to retrieve elements from the Revit database is via filtered element collectors:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.9
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
