Family Instance Orientation
L.Maas
Mentor Mentor
L.Maas
I have some questions about the orientation of family instances. What I am trying to accomplish is to export an image of a family instance. For this I let the user select a family instance in the project. After that I create a new isometric 3D View, isolate that family instance and try to set the the isometric view relative to the orientation of that family. If I have non-hosted families this works fine. I can determine the rotation of the family instance (get locationpoint and from there the rotation). Something like (VB.NET)
Dim ElemPos As Location = FamInstance.Location
Dim ObjectLocationPoint As LocationPoint = TryCast(ElemPos, LocationPoint)
Dim ObjectRotation As Double = ObjectLocationPoint.Rotation
When I have the rotation I can orient the view accordingly (setorientation).
ViewAngle = 135 + ObjectRotation * (180 / Math.PI)
However I have difficulty to get the orientation/rotation of the family instance when they are wall/face based families.
How can I find the rotation of the family instance when it is a hosted element
Hereunder a sketch of what I am trying to do. Grey are non-hosted element green the (face/wall) based elements.
The isometric 3D View should display something like
Louis
Please mention Revit version, especially when uploading Revit files.
JimJia
Dear Louis,
You may try to use API FamilyInstance.FacingOrientation  or FamilyInstance.HandOrientation properties to verify if it works for you.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
L.Maas
Thanks.Have been looking at it. Might be part of the solution.
Not managed to get what I need yet. However that is because I am still struggling with all the transforms and matrix stuff. At the moment still fuzzy how things behave/move in the model and move in relation to what. I will need to do some tests and try to figure it out.
Louis
L.Maas
Finally managed to get results that seems to work (more testing needed). First of all I had a mistake in my code. At some point I tried to convert radians to degrees, however the supplied value was already in degrees, causing unexpected results Smiley Frustrated
Looking through lot of information, especially on the building coder website (@jeremytammik) I finally ended up with something that seems to work.
Dim Trf As DB.Transform = ElementListInstance.GetTransform()
Dim basX As XYZ = Trf.BasisX
Dim basZ As XYZ = Trf.BasisZ
Dim vectorTran As XYZ = Trf.OfVector(Trf.BasisX)
Dim ObjectRotation As Double = Trf.BasisX.AngleOnPlaneTo(vectorTran, Trf.BasisZ) * (180 / Math.PI)
Knowing the angle of the object allowed me to create a 3DView on a position relative to the selected object.
Louis
sologubov_d_v
var objectRotation = XYZ.BasisX.AngleOnPlaneTo(familyInstanceTransform.BasisX, XYZ.BasisZ);
