Family Constraints
Family Constraints
Dale.Bartlett
Family Constraints
Dale.Bartlett
Everyone knows that the correct technique for constructing family geometry is to build the skeleton (reference planes) and then constrain the geometry to the reference planes. What I can't determine in an existing family is whether this is the case. For example, select an extrusion, and "Show Contraints". Even better would be to select an edge of the extrusion and highlight the specific reference planes. Any pointers would be appreciated. Dale
______________
Yes, I'm Satoshi.
jeremytammik
Dear Dale,
I would suggest exploring the model using the element lister and RevitLookup before and after adding a contraint manually to a simple sample model.
http://thebuildingcoder.typepad.com/blog/2015/06/revit-api-task-solving-success-aec-disruption-2016-...
http://thebuildingcoder.typepad.com/blog/2015/06/adn-labs-xtra-multi-version-add-ins-and-cnc-direct....
http://thebuildingcoder.typepad.com/blog/2014/09/debugging-and-maintaining-the-image-relationship.ht...
That will show you what elements are added and how they relate to each other.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Dale.Bartlett
Thanks Jeremy, I'll take your advice. Dale
______________
Yes, I'm Satoshi.
