Failures Preprocessor Not Deleting my Error Messages
arshad.k
arshad.k
Hello Guys!!!
    I have struck in Failure Handling, Error messages not deleting using FailuresPreprocessor...
Can anyone give hand to solve this?
My Execute Method
My Failure Processor
@naveen.kumar.t @jeremytammik @RPTHOMAS108 @sahin.ikbal
longt61
You can only suppress transaction Warnings, not Errors. When Errors happen, user input is required to determine the specific solutions. You can check if it is an Error or Warning using FailureSeverity enumeration.
P/s: in order to remove all warnings, you can use FailuresAccessor.DeleteAllWarnings() instead of using a foreach loop to delete each warning. If the FailureSeverity is not Warning, your code can cause an exception.
