Failed to Upgrade 2019 to 2020
I have a Big Problem with my 2019 Revit File when Upgrading to Revit 2020.
In Revit 2019 the Normal Version Is Opened. but after upgrading to 2020 error messages always appear.
so can't update to version 2020. after cancel the notification and then automatically closed.
Can anyone solve my files when upgraded? thank you
jeremytammik
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
did you find solution about your problem ? i have same... need upgrade old project from 2019 to 2020 and i got exact same problem about warning.
