Failed to open the document revit 2020
zohayb_85
zohayb_85
hi,
I have a file that is corrupt, any way i can get the data out of it. tried audit and detached from central. tried importing it as a link and looked for backup but no luck. tried every given method to recover data but cant seem to find any solution. is there any debug tools or something that can fix it.
here is the file.
https://www.dropbox.com/s/5eulamedghjjkro/CONCEPT%201.rvt?dl=0
any help will be really appreciated.
Zohaib Ali.
jeremytammik
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
