Failed to Load ImagePath
florian.schaeferTJTBZ
i try to Place a Temporary In-Canvas Graphic in Revit like this:
var activeUiDoc = document.Application.ActiveUIDocument;
        var activeDbDoc = activeUiDoc.Document;
        using (var graphicsManager = TemporaryGraphicsManager.GetTemporaryGraphicsManager(activeDbDoc))
            try
                var insertionPoint = activeUiDoc.Selection.PickPoint("Select insertion Point");
                var logoData = new InCanvasControlData(@"C:\Program Files\Autodesk\Revit 2023\uniE1D2.bmp", XYZ.Zero);
                var index = graphicsManager.AddControl(logoData, ElementId.InvalidElementId);
            } catch(Exception ex)
                return;
But i get a "Failed to load the image from specified path." Error message. I have tried various different Paths, the Error stays.
Is there an Issue with the Revit 2023 Api? What can i try to get my image displayed.
Thanks for the help.
ricaun
Looks like is working fine on Revit 2023.
Here is a simple example:
See yaa
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Are you sure you are using Revit2023.exe when i start your project it asks for Revit2022.exe?
ricaun
The default version is 2022 but I tested on Revit 2023.
Thanks a lot for all your Effort and Help.
The Issue was that something changed from 2022-2023 because the .bmp file we used in 2022 had different colored backgrounds. After i changed the Backgrounds to your image background, everything worked.
Thanks again.
