Fail to get reference for grid
Hi.
I want to create dimensions between grids.
I tried two ways but it fails.
the first is
List<Curve> gridCurves = new List<Curve>();
var grids = new FilteredElementCollector(doc).OfClass(typeof(Grid)).Cast<Grid>();
foreach (var grid in grids)
    var curves = grid.GetCurvesInView(DatumExtentType.ViewSpecific, view); // grid.GetCurvesInView(DatumExtentType.Model, view);
    if (curves.Count() > 0)
        if (curves.first().Reference != null) gridCurves.Add(curves.First());
and the second is
var options = new Options();
options.ComputeReferences = true;
options.IncludeNonVisibleObjects = true;
options.View = view;
    foreach (GeometryObject geoObj in grid.get_Geometry(options))
        if (geoObj is Line)
            var line = geoObj as Line;
            if (line.Reference != null) gridCurves.Add(line);
oh, and I tried grid.Curve.GetEndPointReference(0);
I can't get the reference for the grid.
null reference error when creating dimension.
I need your help!
thank you 🙂
thannaingoo.api
I am not sure this is what you need but you may try this.
Naing Oo
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
UIApplication uiapp = commandData.Application;
UIDocument uidoc = uiapp.ActiveUIDocument;
Application app = uiapp.Application;
Document doc = uidoc.Document;
Selection sel = uidoc.Selection;
XYZ start = null;
XYZ end = null;
View view = doc.ActiveView;
Autodesk.Revit.DB.ViewPlan viewPlan = null;
viewPlan = doc.ActiveView as ViewPlan;
if (viewPlan == null)
TaskDialog.Show("Revit", "Go to Plan View!");
return Result.Cancelled;
FilteredElementCollector col = new FilteredElementCollector(doc, view.Id).WhereElementIsNotElementType().OfCategory(BuiltInCategory.OST_Grids);
IList<Element> elementList = col.ToElements();
foreach (Element elmt in elementList)
Grid grid = elmt as Grid;
IList<Curve> gridCurves = grid.GetCurvesInView(DatumExtentType.Model, view);
foreach (Curve c in gridCurves)
start = c.GetEndPoint(0);
end = c.GetEndPoint(1);
TaskDialog.Show("Revit", "Grid StartPoint - " + start.ToString() + "\n" + "Grid EndPoint - " + end.ToString());
return Result.Succeeded;
aignatovich
Hi!
It is enough to reference entire grid for dimensioning purposes.
Just create:
var reference = new Reference(gridElem);
@thannaingoo.api
thank you for your reply!
but I was looking for a way to get grid reference.
@aignatovich
so simple!
it works.. thank you so much!!! Smiley LOL
Arciviz
Working fine for me Also
