Using the code below, I can correctly identify almost all the elements that are inside a room. However, there is one project in which I have encountered difficulties. I have observed that in that project, the linked architectural model uses phasing, whereas the model I was working on does not. However, I cannot say for certain if this is the only issue.
bool isInside = room.IsPointInRoom(location);
Regardless of any phasing, the 'IsPointInRoom' method should be able to accurately detect any element. I am unsure of the possible reason why it is not returning 'isInside' as true. The elements are within the room boundary, and the room bounding is also turned on.
