Extract Rivet Data to windows Form
I want to extract rivet data such as room ID, room name, level on which rooms belong etc. using a button on windows from.
I have gone through Rivet API addin procedure added a manifest file &  successfully able to open a window in Rivet software.
If anyone can just help me with syntax to be used to extract say just one type of data like room ID and display into a listview on the window using click of a button rest of other data I will do it myself.
I have attached below the code to open my window in Rivet.
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using Autodesk.Revit;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
namespace Trial
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    public class Class1 : IExternalCommand
        public Autodesk.Revit.UI.Result Execute(ExternalCommandData revit,
           ref string message, ElementSet elements)
            try
                Form1 f1 = new Form1();
                f1.Show();
            catch(Exception ex)
                MessageBox.Show(ex.Message);
            return Autodesk.Revit.UI.Result.Succeeded;
Below is the screen shot for the window opened in Rivet.
I have gone through many posts & tutorials  but I could not find the solution for the above problem.
Thanks in advance for your help.
Regards
-Faisal
FlorisvdG
You can use the FilteredElementCollector to collect loads of data from an open file.
http://www.revitapidocs.com/2015/263cf06b-98be-6f91-c4da-fb47d01688f3.htm
for example:
List<View> lstAllViews = new FilteredElementCollector(doc).OfClass(typeof(View)).Cast<View>().ToList();
Where doc is the current opendocument, and View is what I want the collector to collect.
The collector returns Elements, so I always cast the elements back to what I'm searching for.
There's almost certainly an example in the Revit SDK, you can check that out too.
