Extract PDF of the ceiling views using API from a closed model
josepht21
josepht21
Hi everybody,
I am still quite new in the API of Revit. I was wondering if there is a way to get a PDF for each view of the Ceiling Views in a model. I also need to do this using a closed model so I don't know if it is even possible to do that. I am using C# in my code.
Thanks in advance
jeremy_tammik
Welcome to the Revit API!
You can export a PDF from any view you like, just as you can manually in the user interface.
I suggest that you simply determine the exact steps and views to execute the process manually first.
I suppose that the PDF is considered an image, so you would use the Document.ExportImage method:
https://www.revitapidocs.com/2021.1/b98a3e71-39fa-bf7a-cb3d-591d8b1fcd93.htm
No, no, it is considered printing, isn't it? So you would use Document.Print.
In any case, it is eminently doable.
However, before trying anything else, though, prepare yourself by working through the getting started material:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#2
Also please pay attention to what you should do before getting started, e.g., learn Revit (hopefully you already have) and maybe dabble a bit with some basic programming, both generic and .NET.
Good luck and have fun!
P.S. I have no idea what a 'closed model' might be. A house with no doors or windows? A prison?
