External Files
External Files
External Files
The following code gets all the files linked or imported in a revit document but how do I get the list of cad files that are linked and not imported:
ModelPath location = ModelPathUtils.ConvertUserVisiblePathToModelPath(doc.PathName);
string path = ModelPathUtils.ConvertModelPathToUserVisiblePath(location);
TransmissionData transData = TransmissionData.ReadTransmissionData(location);
ICollection<ElementId> externalReferences = transData.GetAllExternalFileReferenceIds();
foreach (ElementId refId in externalReferences)
ExternalFileReference extRef = transData.GetLastSavedReferenceData(refId);
string ipath=ModelPathUtils.ConvertModelPathToUserVisiblePath(extRef.GetPath());
if (ipath.Contains(".dwg"))
string fileName = Path.GetFileName(ipath);
categoryname.Add(fileName);
Thanks & Regards
Sanjay Pandey
Hello sanjay,
You can use a FilteredElementCollector
foreach (ImportInstance ii in  new FilteredElementCollector(document)
        .OfClass(typeof(ImportInstance))
        .Cast<ImportInstance>()
        .Where(i => i.IsLinked == true))
Do something....
 Good Luck
/Martin
