Exterior paint legends
ervin.schlabach
ervin.schlabach
Is there an easy way to create a color legend with paints/textures used on the exterior of a building ? I have tried creating walls made of only the paint/material and some show show up white in the legend. It seams the colors are lighter in the legend than on the elevations. See attached. Any thoughts?
recepagah12
This is Revit API forum, this forum is only for Revit API, coding questions. If you aren't trying to solve your problem programmatically, you should look at other Revit Forums.
