Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Exterior face of wall opening
2 REPLIES 2
410 Views, 2 Replies
Hi! I know how to get planar faces of opening, but how determine planar faces which located on exterior face of wall?
Tags (1)
2 REPLIES 2
yimin.chenTW
Hi @Anonymous,
You can use Wall.Orientation to get the external face normal vector which will help you get the face you want.
Please refer this for more information.
Yimin Chen
Developer Consultant
Developer Technical Services
FrankHolidaytoiling
What if the wall is drawn backwards so the exterior is not facing outside? Or at least consistent as some other wall modelling standards might exist?
Forma Design Contest
Rail Community
