ExtensibleStorage Field of value type string[]
Message 1 of 9
Hi all,
I've encountered a problem when I'm trying to store an array of string to a field in a schema using ExtensibleStorage. It throws an InvalidOperationExcpetion on myEntity.Set(myFieldName, myStringArray) saying "Unsupported type: System.String[]"
Pseudocode:
var schemaBuilder = new SchemaBuilder(myGuid);
schemaBuilder.AddArrayField("myFieldName", typeof(string));
var mySchema = schemaBuilder.Finish();
var myField = mySchema.GetField("myFieldName");
var myEntity = newEntity(mySchema);
myEntity.Set(myField, new string[] {"string1", "string2"});
//throws InvalidOperationException: Unsupported type: System.String[]"
Any one have an idea of what I'm doing wrong?
Cheers,
Eirik
Replies (8)
Message 2 of 9
jeremytammik
Dear Eirik,
Yes, absolutely.
Please take a close look at the exact function signature of
myEntity.Set(myField,...
You will immediately see that it does not take a system array argument, but a generic list, templated to contain strings.
myEntity.Set(myField,new List<string>(...
Please also consult the extensive list of extensible storage samples provided by The Building Coder:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.23
It covers this topic and many others as well.
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 9
Revitalizer
what about setting an IList<string> instead of string[] ?
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 4 of 9
Jeremy,
Thank you for your answer.
When i try to use a generic list (List<string>) the following Exception is thrown
Unsupported type: System.Collections.Generic.List`1[[System.String, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]]
I do think the method expects an Array, because in another function we have, we use an array of ElementIds (like new List<ElementId>{myElementId1, myElementId2}.ToArray(), which works like a charm. But a string array is not accepted.
Cheers,
Eirik
Message 5 of 9
Revitalizer
try to use an IList instead of a List. Note the leading "I" 😉
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 6 of 9
jeremytammik
Thank you for your appreciation, and many thanks to Revitalizer for providing the more accurate answers!
Revitalizer is right.
As a computer programmer, we cannot ignore little details like that leading 'I'.
Also, please, in future do look at the samples provided.
This issue has been discussed before and is included in The Building Coder discussions as well.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 7 of 9
An IList worked perfectly 🙂
Thank you very much Revitalizer and Jeremy!
Cheers,
Eirik
PS: Out of curiosity: Why wouldn't a List<T> work, when an IList<T> does work? (Maybe not the right forum, I know)
Message 8 of 9
Revitalizer
Hi eirik,
no idea why we need to use an IList.
But it says in the RevitAPI.chm:
"The types for containers are IList for arrays and IDictionary for maps"
It's on each of the pages of the Entity.Set() method overloads, see "Remarks".
So it's nearly an RTFM question 🙂
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 9 of 9
Revitalizer,
It is definitley a RTFM question. My bad. In hindseight.
Btw, I really love when a manual is needed. And sarcarsm always works well on forums.
Cheers,
Eirik
