Exporting ViewSheet element through ExportContext2D
pmeigneux
Message 1 of 10
pmeigneux
I am trying the use the ExportContext2D to export a ViewSheet type element.
I am receiving the following error:
Here is a sample of code that I use:
            FilteredElementCollector colS = new FilteredElementCollector(Doc).OfClass(typeof(ViewSheet));
            foreach (ViewSheet sheet in colS)
                            try
                                ExporterAdnMeshDS_UPS.ExportContext2D context = new ExporterAdnMeshDS_UPS.ExportContext2D(Doc);
                                CustomExporter exporter = new CustomExporter(Doc, context);
                                exporter.Export(vs);
                                exporter.Dispose();
                            catch (ArgumentNullException e)
                            catch (ArgumentException e)
                            catch (InvalidOperationException e)
Do you know an alternate way to realize the export of a ViewSheet? I was maybe thinking to convert it into another view type. Any best recommendation on it?
Replies (9)
Message 2 of 10
jeremytammik
You are looping over all the ViewSheet elements that you encounter, without checking anything further.
I believe you should always check for and eliminate template views, for instance.
I would suggest that you export the view sheets one by one and determine exactly which one causes a problem.
Maybe it is one that you should be skipping anyway.
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 10
pmeigneux
I don't see anything special on my views (see attachments).
Message 4 of 10
pmeigneux
suite..
Message 5 of 10
pmeigneux
suite..
Message 6 of 10
pmeigneux
is it possible to export by CustomExporter2D viewsheets other than templates?
the viewsheets that I want to export, exort correctly with Doc.Export in dwg.
philippe
Message 7 of 10
jeremytammik
I tried to implement a test and encountered no problem whatsoever.
Here is the result of exporting the Level 1 view with a trivial 2D custom exporter implementation:
Sample view:
Source code:
#region Namespaces
using System;
using System.Collections.Generic;
using System.Diagnostics;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
#endregion
namespace CustomExport2d
  [Transaction( TransactionMode.Manual )]
  public class Command : IExternalCommand
    class CustomExport2dContext : IExportContext2D
      public void Finish()
        Debug.Print( System.Reflection.MethodBase.GetCurrentMethod().Name );
      public bool IsCanceled()
        return false;
      public RenderNodeAction OnCurve( CurveNode node )
        return RenderNodeAction.Proceed;
      public RenderNodeAction OnElementBegin( ElementId elementId )
      public RenderNodeAction OnElementBegin2D( ElementNode node )
      public void OnElementEnd( ElementId elementId )
      public void OnElementEnd2D( ElementNode node )
      public RenderNodeAction OnFaceBegin( FaceNode node )
      public RenderNodeAction OnFaceEdge2D( FaceEdgeNode node )
      public void OnFaceEnd( FaceNode node )
      public RenderNodeAction OnFaceSilhouette2D( FaceSilhouetteNode node )
      public RenderNodeAction OnInstanceBegin( InstanceNode node )
      public void OnInstanceEnd( InstanceNode node )
      public void OnLight( LightNode node )
      public void OnLineSegment( LineSegment segment )
      public RenderNodeAction OnLinkBegin( LinkNode node )
      public void OnLinkEnd( LinkNode node )
      public void OnMaterial( MaterialNode node )
      public RenderNodeAction OnPolyline( PolylineNode node )
      public void OnPolylineSegments( PolylineSegments segments )
      public void OnPolymesh( PolymeshTopology node )
      public void OnRPC( RPCNode node )
      public void OnText( TextNode node )
      public RenderNodeAction OnViewBegin( ViewNode node )
      public void OnViewEnd( ElementId elementId )
      public bool Start()
        return true;
    public Result Execute(
      ExternalCommandData commandData,
      ref string message,
      ElementSet elements )
      UIApplication uiapp = commandData.Application;
      UIDocument uidoc = uiapp.ActiveUIDocument;
      Application app = uiapp.Application;
      Document doc = uidoc.Document;
      View view = doc.ActiveView;
      CustomExport2dContext c = new CustomExport2dContext();
      CustomExporter ce = new CustomExporter( doc, c );
      ce.Export( view );
      return Result.Succeeded;
Output result:
Start
IsCanceled
OnViewBegin
IsCanceled
OnElementBegin2D
IsCanceled
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
OnElementEnd2D
IsCanceled
OnElementBegin2D
IsCanceled
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
OnElementEnd2D
IsCanceled
OnElementBegin2D
IsCanceled
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
OnElementEnd2D
IsCanceled
OnElementBegin2D
IsCanceled
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
OnElementEnd2D
IsCanceled
OnElementBegin2D
IsCanceled
OnInstanceBegin
IsCanceled
OnInstanceEnd
OnElementEnd2D
IsCanceled
OnElementBegin2D
IsCanceled
OnInstanceBegin
OnInstanceEnd
OnElementEnd2D
IsCanceled
OnElementBegin2D
IsCanceled
OnInstanceBegin
OnInstanceEnd
OnElementEnd2D
IsCanceled
OnElementBegin2D
IsCanceled
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
OnElementEnd2D
OnViewEnd
IsCanceled
OnViewBegin
OnViewEnd
IsCanceled
OnViewBegin
IsCanceled
OnElementBegin2D
IsCanceled
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnElementEnd2D
IsCanceled
OnElementBegin2D
IsCanceled
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnElementEnd2D
IsCanceled
OnElementBegin2D
IsCanceled
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnElementEnd2D
IsCanceled
OnElementBegin2D
IsCanceled
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnElementEnd2D
IsCanceled
OnElementBegin2D
IsCanceled
OnInstanceBegin
OnCurve
OnCurve
OnCurve
OnCurve
OnCurve
IsCanceled
OnInstanceEnd
OnElementEnd2D
IsCanceled
OnElementBegin2D
IsCanceled
OnInstanceBegin
OnInstanceEnd
OnElementEnd2D
IsCanceled
OnElementBegin2D
IsCanceled
OnInstanceBegin
OnInstanceEnd
OnElementEnd2D
IsCanceled
OnElementBegin2D
IsCanceled
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
IsCanceled
OnFaceBegin
OnFaceEnd
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnFaceEdge2D
OnElementEnd2D
IsCanceled
OnElementBegin2D
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnElementEnd2D
IsCanceled
OnElementBegin2D
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnElementEnd2D
IsCanceled
OnElementBegin2D
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnElementEnd2D
IsCanceled
OnElementBegin2D
OnPolylineSegments
OnPolylineSegments
OnElementEnd2D
IsCanceled
OnElementBegin2D
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnElementEnd2D
IsCanceled
OnElementBegin2D
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnPolylineSegments
OnElementEnd2D
OnViewEnd
IsCanceled
OnViewBegin
OnViewEnd
Finish
Sample code attached.
Jeremy Tammik
The Building Coder
Message 8 of 10
pmeigneux
don't work with my document (in attachment).
Message 9 of 10
pmeigneux
can no one help?
Message 10 of 10
jeremytammik
Sure.
I tried using the custom exporter that I implemented above (attached) on your sample model and see that you are trying to export a sheet view.
I can reproduce the behaviour you describe:
Please read the documentation on the IExportContext2D interface; it clearly states: An interface that is used in custom export to export 2D views of a Revit model. I am sorry to have to point out that a sheet is not a 2D view of the model. That is presumably the reason why this exception is triggered: the view is not exportable, indeed.
Jeremy Tammik
The Building Coder
