Exporting Shared Parameters to Shared Parameter File Revit 2023
lee6800
lee6800
I am trying to collect all the shared parameters that exists within a family and export them to the shared parameter file.
I have searched the Revit Api Docs and can't find method used to achive this.
Basically I like the know what is the minimum info that is required
just by looking at the  sp file, i can see when done manually, "PARAM", GUID, NAME, DATATYPE, DATACATEGORY, GROUP, VISIBLE,  DESCRIPTION,  USERMODIFIABLE,  HIDEWHENNOVALUE  are populated.
Do I need to extract all these values from the parameters? When I create / export manully, I don't set half of these! so where does Revit gets them from?
This is for Revit 2023 btw, as I know some of the API has changed after Revit 2021
Thanks for your help in advance
jeremy_tammik
I believe it is very simple. Just read the value of the Application object's SharedParametersFilename:
If it is undefined, you can set it to a pathname of your own choice. Afaict, Revit will write the data you describe to that location. You can look at The Building Coder samples module CmdCreateSharedParams.cs, for example:
lee6800
Thank you very much for your help
With the links provided above and this tool here
https://github.com/jeremytammik/RevitSdkSamples/blob/master/SDK/Samples/MultiplanarRebar/CS/SharedPa...
I think I have enough information to finish off my script now
Thanks again for your help
minix6800
how do you get BuiltInParameter Enumeration for revit 2025 and above
for earlier revit versions I used
BuiltInParameterGroup groupEnum = param.Definition.ParameterGroup;
but not sure how to do this is later versions of revit?
thanks
