Exporting in-place families for use in new documents.
jeroenvanlithWWCBG
jeroenvanlithWWCBG
Hi All,
I have a question. I want to re-use in-place furniture families from document A into document B, programmatically.
I have thought of two ways:
option 1: export/save the in-place family from document A to a separate .rfa file.
option 2: load in-place family from document A to document B directly.
But haven't found ways to do this programmatically.
Could anyone help me?
Thanks!
Jeroen
jeremy_tammik
Dear Jeroen,
The API will hardly provide any functionality that is not available in the user interface, so that will be the easiest way to research for the best approach. Afaik, RFA provides no support whatsoever for in-place families; they live in the RVT  environment only. However, as a BIM element in the RVT, it ought to be possible to copy an in-place family between different documents using the CopyElements copy and paste API:
https://www.revitapidocs.com/2023/b22df8f6-3fa3-e177-ffa5-ba6c639fb3dc.htm
Cheers,
Jeremy
jeroenvanlithWWCBG
Thank you for your quick reply Jeremy! I will study your suggestions and update when I've found something.
RPTHOMAS108
If you group the contents of the in-place family in the in-place family editor then you can save the group to a rfa file
However, there is no support for editing in-place families within the API.
jeroenvanlithWWCBG
Thank you, it's a pity I can't edit in-place families in the API.
