Exporting Families to FBX (or OBJ) format
saadXFKKP
saadXFKKP
Hello Autodesk Community,
I'm looking for a way to export multiple Revit families (around 10 specific ones) from my project into individual FBX (or OBJ) files.
Does anyone know how this could be done—using pyRevit, Dynamo, or any other method?
Thanks in advance for your help!
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @saadXFKKP ,
Could you please follow the below suggestion?
  • Collect the instances of the 10 families within the project.
  • Create a temporary 3D view to isolate each family.
  • Export the 3D view to FBX or OBJ format.
  • Delete the temporary 3D view once the export is complete.
Useful Links:
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
saadXFKKP
Thank you, Naveen, for your response.
Currently, I use this method to export families manually. However, I’m looking to automate the process using Dynamo or PyRevit, as I have a large number of Revit building projects from which I need to extract families.
jeremy_tammik
So, run your existing code in a loop iterating over all the desired families, opening them one by one, exporting, and closing. Don't forget to add some logging functionality, in case Revit crashes at some point. If you process hundreds or thousands of documents, this may happen sooner or later. Check out The Building Coder discussions of batch processing:
