Export to DWG and automaticaly bind images
1161314
Message 1 of 11
1161314
Is it possible to make revit export to dwg and binding any images that are placed in the sheets? Something like e-transmit in autocad.
Replies (10)
Message 2 of 11
jeremytammik
If you can achieve what you wish manually in the user interface, then it can probably be driven programmatically by the API as well.
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 11
1161314
I didn't understand your answer. I was asking if is possible to write na addin for revit that manipulates dwg files. In concrete, to bind images in files exported from revit.
Message 4 of 11
jeremytammik
Can you achieve what you need manually in the user interface?
Jeremy Tammik
The Building Coder
Message 5 of 11
1161314
In the Revit interface no.
In autocad, is the etransmit command. Can i cal that command in na addin runnig in Revit?
Message 6 of 11
jeremytammik
The Revit API does not support this. It only supports activities that can also be run manually through the Revit user interface.
However, you can in fact make use of the AutoCAD.NET API as well as the Revit API inside your Revit add-in.
So that should be possible.
Jeremy Tammik
The Building Coder
Message 7 of 11
1161314
So far i've done this:
        public static void Etrans(string desenho,string destination)
            try
                TransmittalFile tf;
                TransmittalOperation to = new TransmittalOperation();
                TransmittalInfo ti = to.getTransmittalInfoInterface();
                System.Windows.MessageBox.Show(desenho);
                to.addDrawingFile(desenho, out tf);
            ti.destinationRoot = destination;
            ti.preserveSubdirs = 0;
            ti.organizedFolder = 0;
            ti.dataLinkRelativePath = 1;
            ti.DGNUnderlayRelativePath = 1;
            ti.DWFUnderlayRelativePath = 1;
            ti.imageRelativePath = 1;
            ti.PDFUnderlayRelativePath = 1;
            ti.xrefRelativePath = 1;
            ti.saveVersion = SaveDwgFormat.eAutoCADR21;
            ti.visualFidelity = 1;
            ti.includeXrefDwg = 1;
            ti.includeUnloadedReferences = 1;
            ti.includeUnloadedXrefDwg = 1;
            ti.includeNestedOverlayXrefDwg = 1;
            ti.BindType = BindType.eBind;
            ti.depathXrefs = 1;
            ti.includeImageFile = 1;
            ti.includeDGNUnderlay = 1;
            ti.includeDWFUnderlay = 1;
            ti.includePDFUnderlay = 1;
            ti.includeDataLinkFile = 1;
            ti.includeFontFile = 1;
            // Reset plotters for layouts in the drawings to None,
            // and include plot style (CTB/STB) files (0 - False, 1 - True)
            ti.resetPlotter = 0;
            ti.includePlotFile = 0;
            ti.includePhotometricWebFile = 1;
            ti.includeMaterialTextureFile = 1;
            ti.purgeDatabase = 0;
            catch (Exception ex)
                System.Windows.MessageBox.Show(ex.ToString());
            try
                //to.createTransmittalPackage();
            catch
                System.Windows.MessageBox.Show("ERRO");
And call it here:
foreach (var f in files)
                        MessageBox.Show(pathArquivo);
                        if(f.FullName.Contains(".dwg"))
                            ZiTools.Etrans(f.FullName, pathArquivo);
But i get this error:
I've created the interop "TRANSMITTALLib.dll" as indicated here:
https://help.autodesk.com/view/OARX/2019/ENU/?guid=GUID-FF7AD257-9C2A-4A4D-8408-FC5C209DC7E8
Message 8 of 11
jeremytammik
To simplify matters, it ill probably be safest for you to develop your AutoCAD.NET add-in as a stand-alone app first, before trying to run it within a Revit add-in. That way, you eliminate one potential cause for problems. If you have any problems in that scenario, I would suggest raising them in the AutoCAD.NET discussion forum.
Jeremy Tammik
The Building Coder
Message 9 of 11
1161314
I've managed to get the dwg database, but i get na error in transation:
Message 10 of 11
1161314
public static void Etrans(string desenho)
            System.Windows.MessageBox.Show(desenho + " Passou");
            Autodesk.AutoCAD.ApplicationServices.Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database myDB = new Autodesk.AutoCAD.DatabaseServices.Database(false, true);
            using (myDB)
                myDB.ReadDwgFile(desenho, FileOpenMode.OpenForReadAndAllShare, true, "");
                System.Windows.MessageBox.Show("DB Passou");
                string verDb = myDB.Ltscale.ToString();
                System.Windows.MessageBox.Show(verDb);
                try
                    System.Windows.MessageBox.Show("Entrou try");
                    DBDictionary nod2 = myDB.NamedObjectsDictionaryId.GetObject(OpenMode.ForRead) as DBDictionary;
                    ObjectId imageDictId2 = nod2.GetAt("ACAD_IMAGE_DICT");
                    string verDit = imageDictId2.IsNull.ToString();
                    System.Windows.Forms.MessageBox.Show(verDit);
                    using (Autodesk.AutoCAD.DatabaseServices.Transaction myTrans = myDB.TransactionManager.StartTransaction())
                        DBDictionary nod = myTrans.GetObject(myDB.NamedObjectsDictionaryId, OpenMode.ForRead) as DBDictionary;
                        ObjectId imageDictId = nod.GetAt("ACAD_IMAGE_DICT");
                        DBDictionary imageDict = myTrans.GetObject(imageDictId, OpenMode.ForRead) as DBDictionary;
                        foreach (DBDictionaryEntry dbDictEntry in imageDict)
                            RasterImageDef rasterImageDef = myTrans.GetObject(dbDictEntry.Value, OpenMode.ForWrite) as RasterImageDef;
                            try
                                if (System.IO.File.Exists(rasterImageDef.SourceFileName))
                                    dynamic dwgPathUri = new Uri(desenho);
                                    dynamic rasterImagePathUri = new Uri(rasterImageDef.SourceFileName);
                                    // Make the raster image path
                                    // relative to the drawing path
                                    dynamic relativeRasterPathUri = dwgPathUri.MakeRelativeUri(rasterImagePathUri);
                                    // Set the source path as relative
                                    rasterImageDef.SourceFileName = Uri.UnescapeDataString(relativeRasterPathUri.ToString());
                                    // Reload for AutoCAD to
                                    // resolve active path
                                    rasterImageDef.Load();
                                    // Check if we found it
                                    //RasterImage raster = new RasterImage();
                                System.Windows.MessageBox.Show("Erro_Raster");
                            myDB.SaveAs(desenho, DwgVersion.Current);
                            myDB.Dispose();
        #endregion
This is the code, called by:
                            ZiTools.Etrans(f.FullName);
Message 11 of 11
1161314
Just for the record, i've made it. But i had to use cad core manager.
