Export Revit Parameters to Invetor
anandhvpt
Observer Observer
anandhvpt
Observer
Observer
Hi Team
I have the revit Assembly with all the properties. Now i would like to export the revit models to invnetor and create the drawings from that.
I have exported the SAT fromat, it opens in inventor but the properties am not able to get that
Is there any way to get the Revit properies as custom parameter in inventor
Can you share if any sample code for that
Thanks & Regards
Anandh
jeremy_tammik
Yes, sure. Lots of such samples have been published all over the place. What you are looking for are the model parameters.
The first place to look is normally in the Revit SDK samples, accessible in the Revit Developer Centre:
E.g., look at the FireRating sample for a simple round-trip export-modify-import sample. An overview of parameter-related samples is given in the readme file:
  • RevitSdkSamples/SDK/Samples/SamplesReadMe.htm
You might also want to check out The Building Coder blog for parameter export:
By the way, you would probably be able to find an answer this question very quickly (more quickly) yourself by searching this forum first.
anandhvpt
Observer
Observer
Hi
Thanks For your Reply.
I will go around it and let you know if any clarification required
