Export Revit file to IFC using VB.NET/C#
Hi Guys,
This is balaji, i am new to Revit API programming. I am started the exploring method API process.
Currently, i am looking for export current revit file to IFC format, through VB.NET/C#.  How to do the export process.
Please help me for further process and guidance.
Thnks
Balaji
jeremytammik
Dear Balaji,
Yes, it is.
You can implement a Revit add-in in C# .NET to drive the  RVT to IFC export using the Document.Export method:
http://www.revitapidocs.com/2017/2f535342-ee41-86f9-0022-92ba1f65112d.htm
http://www.revitapidocs.com/2017/db8ed2bb-8949-7a7f-e09a-29f6c9916f42.htm
Another option is to translate the RVT to Forge and export IFC from there:
https://developer.autodesk.com/en/docs/model-derivative/v2/overview/supported-translations/
In that case, you can work in the cloud and do not need to have Revit installed at all.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Hi Jeremy,
Thanks for your immediate reply. I will check with your provided urls for further process.
Is there any option to open revit files outside vb macro like vb.net application
i.e: User has to open form and select the revit file from file browsing. After file selected, function should open revit file in the background of the application and export to IFC file format.
I searched in the forum and other guide, i got little bit confused with provided sample coding.
Actually i created one vb.net form and given the option to user select revit files and export-button.
I am looking application(form based) oriented process for our requirement.
Thnks
Balaji
jeremytammik
Hi Jeremy,
Sorry for disturbing you.
Can you suggest to learn from basic level to advance method. Like PDF/HTML.
Actually i download one project from net "importexport-vb.net.zip", if i try to run the project it show error in the common class areas.
I have attached the zip file for your reference.
errors:
1. SelectViewsForm.vb
     Autodesk.Revit.Elements.View
2. Command.vb
    IExternalCommand
3. Units.vb
    Autodesk.Revit.Enums.DisplayUnitType
Thnks
Balaji
jeremytammik
Please work through the basic getting started material before asking any further questions:
https://forums.autodesk.com/t5/revit-api-forum/starting-out-using-revit-api/m-p/7569859
Thank you!
Cheers,
jeremy
Jeremy Tammik
The Building Coder
Sorry Jeremy,
Thanks for your provided url, i will go through the guide and start basic level of programming..
Thnks
Balaji
