Export Revit Elements to .SAT with python.
o.nerwa
Observer Observer
o.nerwa
Observer
Observer
Is it possible to export revit elements to .SAT by first converting them to Geometry then exporting this Geometry. By not using a view. With Dynamo this is possible by converting the element to geometry using the Element.Geometry node, then convering it to .SAT with the ExportToSat node. No seperate view is needed for this export.
I was wondering if this would be possible with python (pyrevit) and the API.
jeremy_tammik
It sounds to me as if that workflow uses Dynamo-specific functionality that is not provided by the Revit API. Here are some possible alternative routes:
