Export DWG Error section Head
mr.engineer.aec
mr.engineer.aec
 Hi All,
I exported by code:
DWGExportOptions opt = new DWGExportOptions();
                 opt.MergedViews = true;
Doc.Export(ExportDWGFolderPath, DWGName, views, opt);
 but detail number in section head error like pic:
in AutoCADin AutoCAD
In Revit:
in Revitin Revit
jeremytammik
What is the result of performing the same export manually though the end user interface?
If it is identical, this is a product support issue that can be addressed in one of the non-API forums.
If the manual export works fine, please submit a minimal reproducible case that we can share with the Revit API development team for analysis and rectification:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Thank you!
Jeremy Tammik
Developer Technical Services
The Building Coder
