Export Data to csv files from Revit using Python
ying_caiCUHMV
ying_caiCUHMV
Hi Community,
Does anyone know ways/references to export Revit elements data to a csv file using Python? either inside Revit program or without opening the program. I wonder how to make it work both ways. Thank you so much!
Yien_Chao
@ying_caiCUHMV  did you start some coding?
ying_caiCUHMV
Hi @Yien_Chao
yes. I was able to generate all parameters of one piece of element from Revit and ran the code in RevitPythonShell. Now, I'm trying to generate the data out as CSV files and searching ways to run the code either with opening the Revit program or without opening the program.
Yien_Chao
sorry, i only code in python inside dynamo.
ying_caiCUHMV
I know there is a way to export data into a csv in Dynamo. But as for now I'm trying to transit from dynamo to revit api. Appreciated your replies.
Yien_Chao
