export data in viewplan
in viewer3d,i can export data with CustomExporter.But in viewplan,how can I export the datas?
jeremytammik
Not so easily, I'm afraid.
What exactly are you after?
My simplified 2D room editor shows how to export 2D room boundaries with furniture and equipment outlines to SVG:
https://github.com/jeremytammik/RoomEditorApp
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
aignatovich
Hi!
Export to DWF or DWFX and reading exported file can also be an option
dear jeremy:
thanks for your reply!
I've read the sample you provided.expect furniture and equipment,I want to export all information in ViewPlan,as I saw in Revit.
how can I export data like f2d file which used in forge viewer.
I cann't get any geometry info in grid,idependenttag and some other annotated element.
jeremytammik
The only way to translate to Forge is to make use of the Forge translation service:
https://autodesk-forge.github.io
https://developer.autodesk.com/en/docs/data/v2/overview
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
