Existing revit command binding with custom made button
hello ,
I have a custom panel and a series of custom button I want to bind one of the them with "EXISTING Revit Command".
but I don't know how .
please advise.Thanks;
franciscopossetto
Hey,
I am not sure if you can do this with all Revit commands, but you can try using the PostCommand method.
On this thread, there is a sample where you can see how to call the Purge Unused command.
https://forums.autodesk.com/t5/revit-api-forum/uiapp-postcommand-then-press-quot-enter-quot-quot-ok-...
Kind regards.
Github:
https://github.com/franpossetto
hi ,thanks for your quick respond.I didnt  find the command I want in postcommand.I tried it before. and also i tried to copy some existing revit panel to get the result but unfortunatly I didn't get to what I meant.
forexample some sketchgallery item in modify button for drawing modle lines such as circle ,Line,Rectangle and so on.
but I couldnt because in the regular state of modify tab ,There are  not  that sketchgallery .
that sketch gallery only apper in Modify tab only after the draw line command are activated.
Thanks so much,
