Excution error
Excution error
atk_vinay.krishna
Excution error
atk_vinay.krishna
Dear all,
i have find some codes to join the floor and walls through revit api.For the same i am attched link from boostyourbim.
https://boostyourbim.wordpress.com/2015/07/24/rtcna-wish-3-granted-join-all-walls-and-floors/
code excuting succusfully at first time  but it is showing error at second time of excution at same model,what is the solutions to avoid the error how to implement the code.
Please kindly go through the attached screen shot.
Regards
Vinay
augusto.goncalves
If you're using JoinGeometryUtils.JoinGeometry you can check if the elements are already joined with JoinGeometryUtils.AreElementsJoined method.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
atk_vinay.krishna
If you dont mind can you give me the sample exmple for JoinGeometryUtils.AreElementsJoined.
Regards
Vinay
arnostlobel
vinay:
the code you asked for is so trivial that I almost woder whether it is what you meant to ask:
if (false == JoinGeometryUtils.AreElementsJoined(doc, elem1, elem2))
   JoinGeometryUtils.JoinGeometry(doc, elem1, elem2);
Arnošt Löbel
Mohamed.ShafeerAhamed
thank for your reply.
