Exchange an Family
Exchange an Family
Message 1 of 12
Exchange an Family
Is it possible to exchange an Family by another Family ?
I have in my model a pipe with a valve from Honeywell, and I would like to replace it with one from Oventrop
First family - Honeywell with type TB10
Second family -  Oventrop  with type OT15
Replies (11)
Message 2 of 12
AGGilliam
Are you just trying to replace an instance of a family that's been placed? If so you can select the instance and set its Symbol property equal to the Family Type you want to switch it to.
Message 3 of 12
an instance
Message 4 of 12
joshua.lumley
Have you tried match properties?
Message 5 of 12
RPTHOMAS108
I take it from your posting history this is an API question rather than UI?
I'm no expert on MEP categories but the usual generic way you change one ElementType for another is by:
Element.ChangeTypeId
Generally if you change an ElementType from what it currently is to one from another family of the same category so be it.
You should review if there are any utility methods within Plumbing namespace to see if there is anything better than the above (to maintain other relationships that may be affected by such a change which I'm not aware of).
Message 6 of 12
sorry my fault 🙄, no the family is already modeled in the model, but because of the price or the customer's choice we have to change brands
so it's not an instance
Message 7 of 12
joshua.lumley
Keep the family but change the manufacturer parameter so that it appears correct in schedules.
Message 8 of 12
yes, but the dimensions of the valve are not the same
Message 9 of 12
RPTHOMAS108
Are you encountering problems with .ChangeTypeId (Families contain types not instances).
Instance based dimensions should remain the same type based ones will change to what is relevant for the type.
Message 10 of 12
ahmed.errazak
thank you all, it works
Message 11 of 12
joshua.lumley
May I be the accepted solution...I put in more work than RPTHOMAS108 .
Cheers,
J
(not a douchebag)
Message 12 of 12
ahmed.errazak
Sorry, I was so glad that it worked, that I didn't pay attention to my answer
Definitely Joshua and thanks again
