Exception thrown: 'Autodesk.Revit.Exceptions.InternalException' in RevitAPI.dll
mabbasT3S75
mabbasT3S75
I was debugging my add-in when I got the following error.
An exception of type 'Autodesk.Revit.Exceptions.InternalException' occurred in RevitAPI.dll but was not handled in user code
No valid type for the assembly instance.
I googled about Internal Exception and learned from thebuildingcoder.com that Internal Exceptions are to be passed back to Autodesk for diagnostics.
The error occurred at this location in my code:
AssemblyInstance assemblyInstance = AssemblyInstance.Create(doc, collection, categoryId);
assemblyInstance.AssemblyTypeName = assemblyInteger.ToString();
Any help will be much appreciated!
Are you using a transaction to create the assembly instance? I am guessing that is needed. This can be done like this:
using (Transaction tx = new Transaction(doc))
tx.Start("Creating Assembly Instance"); AssemblyInstance assemblyInstance = AssemblyInstance.Create(doc, collection, categoryId);
tx.Commit(); }
Also, you can use a try/catch statement to retrieve more information about the crash:
try
assemblyInstance.AssemblyTypeName = assemblyInteger.ToString(); } catch (Exception ex) { TaskDialog.Show("Crash",ex.message);
throw; }
I hope this helps
mabbasT3S75
Yes, I have used a transaction. Again the purpose of try-catch is to find the error but it will not tell you at what line does the error occur. A debugger is good for identifying the exact location of the error. The specific error is:
"No valid type for the assembly instance."
According to the Revit API, AssemblyInstance.Create() should return type AssemblyInstance but that gives me an error, as noted in my question.
mabbasT3S75
@Anonymous Thanks for trying to help me out. So I figured out what was going wrong. The thing is that when the assembly instance was created, Revit did not know it has been created because the changes were never committed and it was left wondering at the next line, what on earth is this assembly instance the user is talking about. This was fixed quite easily by just committing the changes before modifying the newly created assembly instance.
So here is the final solution to your code with some modifications:
   tx.Commit();
   tx.Start("Modify assemblyInstance");
   tx.Commit();
Thanks once again for trying to help me out.
Cheers mate!
