Error using FamilyCreate.NewSweep
dirk.neethling
dirk.neethling
after successfully creating sweeps in a Project doc, with support from Revitalizer, I decided to try this in a Family doc.
I managed to create the sweep Profile, and transform it so that it is perpendicular to the sweep path, see pic:
In order to call FamilyCreate.NewSweep, I created the following parameters:
path,
pathPlane_l,
sweepProfile_l,
The path Parameter is a circle as follows:
CurveArray path = new CurveArray();
XYZ Center = new XYZ(0,0,0);
double planeRadius = 2d;
Plane plane = new Plane(XYZ.BasisZ, center);
Arc arc1 = Arc.Create(plane, planeRadius, 0.0, Math.PI);
Arc arc2 = Arc.Create(plane, planeRadius, Math.PI, Math.PI * 2);
path.Append(arc1);
path.Append(arc2);
The SketchPlane is as follows:
SketchPlane pathPlane_l = SketchPlane.Create(famDoc, plane);
The sweep Profile is created as follows:
var _profilepoints = new List<XYZ>() {
MmToFootPoint(new XYZ(-10,0,0)),
MmToFootPoint(new XYZ(-11.36,-7.7,0)),
MmToFootPoint(new XYZ(-14.15,-10.49,0)),
MmToFootPoint(new XYZ(-13,-16.5,0)),
MmToFootPoint(new XYZ(-11,-16.5,0)),
MmToFootPoint(new XYZ(-10.27,-13.78,0)),
MmToFootPoint(new XYZ(-9.41,-12.5,0)),
MmToFootPoint(new XYZ(-7.95,-12,0)),
MmToFootPoint(new XYZ(-6.49,-12.5,0)),
MmToFootPoint(new XYZ(-5.63,-13.78,0)),
MmToFootPoint(new XYZ(-4.91,-16.5,0)),
MmToFootPoint(new XYZ(-2.91,-16.5,0)),
MmToFootPoint(new XYZ(-2.18,-13.78,0)),
MmToFootPoint(new XYZ(-1.4,-12.5,0)),
MmToFootPoint(new XYZ(0,-12,0)),
MmToFootPoint(new XYZ(1.4,-12.5 ,0)),
MmToFootPoint(new XYZ(2.18,-13.78,0)),
MmToFootPoint(new XYZ(2.91,-16.5,0)),
MmToFootPoint(new XYZ(4.91,-16.5,0)),
MmToFootPoint(new XYZ(5.63,-13.78,0)),
MmToFootPoint(new XYZ(6.49,-12.5,0)),
MmToFootPoint(new XYZ(7.95,-12,0)),
MmToFootPoint(new XYZ(9.41,-12.5,0)),
MmToFootPoint(new XYZ(10.27,-13.78,0)),
MmToFootPoint(new XYZ(11,-16.5,0)),
MmToFootPoint(new XYZ(13,-16.5,0)),
MmToFootPoint(new XYZ(14.15,-10.49,0)),
MmToFootPoint(new XYZ(11.36,-7.7,0)),
MmToFootPoint(new XYZ(10,0,0)),
profileLoop = new CurveLoop();
for (int i = 0; i < (_profilepoints.Count - 1); i++)
Line line = Line.CreateBound(_profilepoints[i], _profilepoints[i + 1]);
profileLoop.Append(line);
//transform it into the sweep plane
var tangent = initV.Direction.CrossProduct(XYZ.BasisZ);
//translate the profile to the starting point
var startingPointOfSweep = initV.GetEndPoint(0);
Curve curve = profileLoop.First();
var startPointOfProfile = curve.GetEndPoint(0);
var translation = startingPointOfSweep - startPointOfProfile;
var transform = Transform.CreateTranslation(translation);
profileLoop.Transform(transform);
//flip the profile vertical around this tangent
transform = Transform.CreateRotationAtPoint(tangent, Math.PI / 2.0, startingPointOfSweep);
CurveArray arr = new CurveArray();
foreach (var item in profileLoop)
arr.Append(item);
start = item.GetEndPoint(0); ;
fin = item.GetEndPoint(1);
var l_ = Creator.CreateModelLine(famDoc, start, fin);
curveArrArr.Clear();
curveArrArr.Append(arr);
SweepProfile sweepProfile_l = famDoc.Application.Create.NewCurveLoopsProfile(curveArrArr);
This call cracks:
Sweep solid = famDoc.FamilyCreate.NewSweep(
true,
path,
pathPlane_l,
sweepProfile_l,
0,
ProfilePlaneLocation.Start);
Error message:
{"One of the conditions for the inputs was not satisfied. Consult the documentation for requirements for each argument."} System.Exception {Autodesk.Revit.Exceptions.ArgumentException}
What am I doing wrong?
Regards,Dirk
FAIR59
for the newsweep method, you mustn't transform the profile. the curve(s) need to be in the XY-plane.
profileType: Autodesk.Revit.DB SweepProfile
The profile of the newly created Sweep. This may contain more than one curve loop or a profile family. The profile must lie in the XY plane, and it will be transformed to the profile plane automatically. Each loop must be a fully closed curve loop and the loops must not intersect. The loop can be a unbound circle or ellipse, but its geometry will be split in two in order to satisfy requirements for sketches used in extrusions.
dirk.neethling
Hello FAIR59,
thanks for answering.
I generate the Profile as follows, so I assume it is in the XY-plane:
I removed the transform, but the result is still that the Profile is not being swept along the arc
Regards, dirk
FAIR59
hello dirk,
i can't find  anything wrong with the pieces of code you provided.
possibilities:
  1. check if MmToFootPoint returns a Z-value of 0
  2. the "stick" in your picture shouldn't be part of the profile
  3. in between the pieces of code, do you change something?  ( path, pathPlane_l )
this is my testing code,  (it works in Revit 2016)
    public static partial class Extensions
        public static XYZ MmToFootPlanePoint(this Plane plane, UV pt)
            return plane.Origin+ plane.XVec.Multiply(pt.U/304.8)+plane.YVec.Multiply(pt.V/304.8);
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    public class Fa_Test : IExternalCommand
        public Result Execute(ExternalCommandData revit, ref string message, ElementSet elements)
            StringBuilder sb = new StringBuilder();
            try
                Document famDoc = revit.Application.ActiveUIDocument.Document;
                if (!famDoc.IsFamilyDocument) return Result.Failed;
                using (Transaction t3 = new Transaction(famDoc, "test"))
                    t3.Start();
                    XYZ Center = new XYZ(0, 0, 0);
                    Plane plane = new Plane((XYZ.BasisX+XYZ.BasisZ).Normalize(), Center);
                    path.Append(arc1);
                    path.Append(arc2);
                    Plane LoopPlane = new Plane(XYZ.BasisZ, Center);
                    //SketchPlane loopPlane_l = SketchPlane.Create(famDoc, LoopPlane);
                            LoopPlane. MmToFootPlanePoint(new UV(-10,0)),
                            LoopPlane. MmToFootPlanePoint(new UV(-11.36,-7.7)),
                            LoopPlane. MmToFootPlanePoint(new UV(-14.15,-10.49)),
                            LoopPlane. MmToFootPlanePoint(new UV(-13,-16.5)),
                            LoopPlane. MmToFootPlanePoint(new UV(-11,-16.5)),
                            LoopPlane. MmToFootPlanePoint(new UV(-10.27,-13.78)),
                            LoopPlane. MmToFootPlanePoint(new UV(-9.41,-12.5)),
                            LoopPlane. MmToFootPlanePoint(new UV(-7.95,-12)),
                            LoopPlane. MmToFootPlanePoint(new UV(-6.49,-12.5)),
                            LoopPlane. MmToFootPlanePoint(new UV(-5.63,-13.78)),
                            LoopPlane. MmToFootPlanePoint(new UV(-4.91,-16.5)),
                            LoopPlane. MmToFootPlanePoint(new UV(-2.91,-16.5)),
                            LoopPlane. MmToFootPlanePoint(new UV(-2.18,-13.78)),
                            LoopPlane. MmToFootPlanePoint(new UV(-1.4,-12.5)),
                            LoopPlane. MmToFootPlanePoint(new UV(0,-12)),
                            LoopPlane. MmToFootPlanePoint(new UV(1.4,-12.5 )),
                            LoopPlane. MmToFootPlanePoint(new UV(2.18,-13.78)),
                            LoopPlane. MmToFootPlanePoint(new UV(2.91,-16.5)),
                            LoopPlane. MmToFootPlanePoint(new UV(4.91,-16.5)),
                            LoopPlane. MmToFootPlanePoint(new UV(5.63,-13.78)),
                            LoopPlane. MmToFootPlanePoint(new UV(6.49,-12.5)),
                            LoopPlane. MmToFootPlanePoint(new UV(7.95,-12)),
                            LoopPlane. MmToFootPlanePoint(new UV(9.41,-12.5)),
                            LoopPlane. MmToFootPlanePoint(new UV(10.27,-13.78)),
                            LoopPlane. MmToFootPlanePoint(new UV(11,-16.5)),
                            LoopPlane. MmToFootPlanePoint(new UV(13,-16.5)),
                            LoopPlane. MmToFootPlanePoint(new UV(14.15,-10.49)),
                            LoopPlane. MmToFootPlanePoint(new UV(11.36,-7.7)),
                            LoopPlane. MmToFootPlanePoint(new UV(10,0)),
                    CurveLoop profileLoop = new CurveLoop();
                        arr.Append(item);
                        XYZ start = item.GetEndPoint(0); ;
                        XYZ fin = item.GetEndPoint(1);
                        sb.AppendLine(string.Format("{0}", start));
                        //var l_ = famDoc.FamilyCreate.NewModelCurve(Line.CreateBound(start, fin), loopPlane_l);
                    CurveArrArray curveArrArr = new CurveArrArray();
                    Sweep solid = famDoc.FamilyCreate.NewSweep(true, path, pathPlane_l, sweepProfile_l, 0, ProfilePlaneLocation.Start);
                    t3.Commit();
                TaskDialog.Show("debug", sb.ToString());
                return Result.Succeeded;
            catch (Exception ex)
                TaskDialog.Show("catch", ex.ToString());
dirk.neethling
Hello FAIR59,
thanks very much, your solution works fine. I'll use that as an incubator.
Regards, Dirk
dirk.neethling
One more question: when I use your static class,
            return plane.Origin + plane.XVec.Multiply(pt.U / 304.8) + plane.YVec.Multiply(pt.V / 304.8);
I get the following compiler error:
"Error 13 Extension method must be defined in a non-generic static class"
FAIR59
the extension class can't be a nested class. You have to define it directly in the namespace.
namespace FAIR_Space
In this case (profile in XY-plane) the method is a bit of overkill for the profilePoints , and you could use your own method MmToFootPoint, provided that the return XYZ has Z-value =0
