Error says floors are overlapping but are not.
So my office has updated to Revit 2019 and we have found a new error that is causing some problems with keeping errors down. Our interiors department draws a floor that is separate of the concrete slab and offset it up 1/8" so they are not overlapping and you can see the hatch. Now after updating to Revit 2019, it says that the floors are overlapping when they clearly are not. The finish floor is only 1/8" and lays on top of the concrete slab. We have a hundred or more errors because of this. Anyone else have this problem? Makes it hard to keep the errors down with this issue.
Jacob.westergaard
Autodesk Support
Autodesk Support
Hi Eric,
Thank you for taking your time to post this on the forum,
Would it be possible for you to share a small test model with us?
I would be more than happy to take a look at it and see what's causing the errors to generate.
Best Regards,
Jacob Westergaard
Autodesk Premium Support Team
AEC Premium Support Services
I could send you the project that it's happening in. I have tried myself to recreate the issue in a new file and everything is fine and no errors appear. It literally is only happening in this model.
Jacob.westergaard
Autodesk Support
Autodesk Support
Yeah that was my suspicion, could you send me a file sharing link in a PM?
It will of course not be shared with anyone else.
Best Regards,
Jacob Westergaard
Sent you a PM
