Error "Third party updater "WatchUpdaterWidows" has experienced a problem and its action had to be canceled." when use DMU
068335643
068335643
I try to use DMU in my code and it works (I need to type parameters and write to the element instance) But when I change something in the type (not related to the geometry) everything breaks and this error pops up.
   class WatchUpdaterWidows : IUpdater
        static AddInId _appId;
        static UpdaterId _updaterId;
        public WatchUpdaterWidows(AddInId id)
            _appId = id;
            _updaterId = new UpdaterId(_appId, new Guid(
              "fafbf6b2-4c06-42d4-97c1-d1b4eb593eff"));
        public void Execute(UpdaterData data)
            Document doc = data.GetDocument();
            Application app = doc.Application;
            foreach (ElementId id in data.GetModifiedElementIds())
                var listWindows = new List<Element>();
                FamilyInstance familyInstance = doc.GetElement(id) as FamilyInstance;
                listWindows.Add(familyInstance);
                new WindowParamertSet(listWindows, doc, WindowParamertSet.UseCase.SetError);
                //if (familyInstance != null)
                //    if (data.IsChangeTriggered(id, Element.GetChangeTypeParameter(new ElementId(BuiltInParameter.LOAD_COMMENTS))))
                //        break;
        public string GetAdditionalInformation()
          return  "Constrol.Com";
        public ChangePriority GetChangePriority()
            return ChangePriority.DoorsOpeningsWindows;
        public UpdaterId GetUpdaterId()
            return _updaterId;
        public string GetUpdaterName()
            return "WatchUpdaterWidows";
       public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Application app = uiapp.Application;
            Document doc = uidoc.Document;
            if (null == updater)
                var updater = new WatchUpdaterWidows(app.ActiveAddInId);
                UpdaterRegistry.RegisterUpdater(updater);
                ElementCategoryFilter filter = new ElementCategoryFilter(BuiltInCategory.OST_Windows);
                UpdaterRegistry.AddTrigger(updater.GetUpdaterId(), filter, Element.GetChangeTypeGeometry());
            else
                UpdaterRegistry.UnregisterUpdater(updater.GetUpdaterId());
                updater = null;
            return Result.Succeeded;
Waht's  wrong?
jeremy_tammik
Your updater has an error.
Please try to debug it.
One possible reason: you are generating an infinite recursion. I.e., you react to a change, perform a modification in your updater, that causes a change, that calls your updater again, etc., ad infinitum.
Sean_Page
I think the issue you are experiencing is that you are only filtering on a category, which can include the Types of the windows as well. Since you are casting it directly to a FamilyInstance its breaking.
Try something like this to check if you have a Family first.
if(doc.GetElement(id) is FamilyInstance familyInstance)
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
ivo.lafeber
I have the same problem, I have 2 lists of builtin categories which also creates this error.
el is the selected element
If E_Category_List.Contains(el.Category.BuiltInCategory) Or GM_Category_List.Contains(el.Category.BuiltInCategory) Then
 changed it to this line, the builtincategory was the problem in the line above
the contains was oke, but, that's what chatgpt answered when I asked to remove the contains function in the line above :).
If E_Category_List.IndexOf(CType(el.Category.Id.IntegerValue, BuiltInCategory)) <> -1 Or GM_Category_List.IndexOf(CType(el.Category.Id.IntegerValue, BuiltInCategory)) <> -1 Then
