Error - Navisworks Exporter is not available in the installed Revit
I get the above error. Thing is I know it is installed and can be exported manually from the add-in
I can confirm it works when I log into the other user account on this machine so it is just this user.. Any ideas?
Thanks.
Also it seems to be loading on build in thne output window...
'Revit.exe' (Managed (v4.0.30319)): Loaded 'C:\Program Files\Common Files\Autodesk Shared\Navisworks\2015\nwexportrevit2015\nwexportrevit2015_12.dll'
alexeykomlev
I faced the same problem. Did you manage to find a solution? What was the cause of the error?
