Error message: System.IO.FileNotFoundException: Could not load file or assembly "System.Collections"
s193801T3FQ5
s193801T3FQ5
I am in the middle of creating a Revit plugin. I am trying to add a dictionary (a member of the System.Collections assembly) which causes the plugin to crash. I am met with the following error message:
Does anyone know how I can fix this issue? Thanks!
RPTHOMAS108
Check fuslog
You'll have to turn on binding log as noted in the message. The log above lists how the assembly is being probed for.
It often come down to looking for the assembly in the same folder as Revit.exe (obviously you don't want to put it there).
I don't recall all the various ways of fixing this but one way is via:
AppDomain.AssemblyResolve Event (System) | Microsoft Learn
s193801T3FQ5
Hello, thanks for the reply.
I found this resource about turning on the binding log: https://stackoverflow.com/questions/255669/how-to-enable-assembly-bind-failure-logging-fusion-in-net
However, it didn't work. I got the following error message:
I'm not quite sure how to understand the link you sent. Am I supposed to add those code snippets to my C# project?
mhannonQ65N2
It looks like you might be trying to load the wrong version of the assembly. Most of the System.* assemblies Revit uses are version 4.7 something or 4.8 something, likely since Revit uses .NET framework. Is your project directly referencing the 6.0.0 version of either of those two assemblies?
