Error in Springs.FamilyInstance.ByGeometry in Revit 2024
thinthin_net
New Member New Member
thinthin_net
New Member
New Member
Hello,I am a beginner user of Dynamo , and trying to generate Revit families from solid created by  Dynamo. I used Springs.FamilyInstance.ByGeometry note in Dynamo. I received the results as null. Could you please see my scripts and give me suggestions. Thank you very much.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @thinthin_net ,
Please note that this discussion forum is dedicated to programming Revit using the Revit .NET API.
Since your question is related to Dynamo, you will likely receive more relevant answers by posting it in the Dynamo forum: https://forum.dynamobim.com/
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
thinthin_net
New Member
New Member
Oh..Thank you for your information.
