error CS1503: Argument 1: cannot convert from 'System.Collections.Generic.List<string>' to 'string'
Hey, i'm making this game and this error just showed up and i cant find a way to solve it. Pls help :'(((
using System.Collections;
using System.Collections.Generic;
using UnityEngine.UI;
using TMPro;
using UnityEngine;
public class FullScreen : MonoBehaviour
public Dropdown resolutionDropdown;
Resolution[] resolutions;
void Start()
resolutions = Screen.resolutions;
resolutionDropdown.ClearOptions();
List<string> options = new List<string>();
for (int i = 0; i < resolutions.Length; i++)
string option = resolutions[i].width + "x" + resolutions[i].height;
options.Add(options);
resolutionDropdown.AddOptions(options);
public void SetFullCreen (bool isFullScreen)
Screen.fullScreen = isFullScreen;
joshua.lumley
lol, I was about to say this is a rookie error, then I realized you on the wrong website altogether.
This is a Revit API forum.
MarryTookMyCoffe
how some one can fail so much, maybe life of programmer is just not for you.
btw you made typo here
 but you probably will not read this just like you didn't read a exception description, debug info in unity, name of the forum and probably your own code.
do not worry it only gonna take Autodesk 5 years to fix bug
mhannonQ65N2
This is actually a very simple error that is easy to make (the error in the code that is). In your for loop you typed options.Add(options); instead of options.Add(option);.
