error addin
error addin
GHASEM_ARIYANI
Advisor Advisor
error addin
GHASEM_ARIYANI
hello everyone
i write a text c# code and  build debugging and create *addin file, then copy and past to revit add-ins folder. but not working.
where is my problem ?
thanks a lot
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
RPTHOMAS108
I believe your full class name is:
{DefaultNameSpace}.SelectElement.SelectElementRevit
You'll have to look in your project properties to get the name of the actual default namespace
If the default namespace is set to 'SelectElement'
then your full class name is:
GHASEM_ARIYANI
hello sir @RPTHOMAS108
Thanks a lot
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
