Error 404
Error 404
Error 404
Hi I have a problem with activation autodesk Revit 2015 64-bit and Autodesk Robot, the problem is that when I clicked on "Activate" and next "Continue" the next screen was "Processing Error":
Your online activation request has returned an error (400) which is not allowing your request to be processed using our automated systems.
 Click the "Use another method" link below to complete the necessary forms and submit your request to the local Autodesk Business Center for your area. A Customer Service Representative will respond within the next 2 business days.
I have a student licens, and have used it before with out any problems.
rosalesduquej
Most likely you will not get an answer from this Forum community since Revit API forum is for API (Application Programming Interface) questions only.
For non-API questions, please choose other forums that is more appropriate. For example,
Installation and licensing:
http://forums.autodesk.com/t5/installation-licensing/bd-p/24
Revit Architecture (including common platform product usage questions):
http://forums.autodesk.com/t5/revit-architecture/bd-p/133
Revit Structure:
http://forums.autodesk.com/t5/revit-structure/bd-p/153
Revit MEP:
http://forums.autodesk.com/t5/revit-mep/bd-p/188
Good luck with your Activation problem.
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
I'm sorry, and thank you.
rosalesduquej
Nothing to worry about 🙂 it happens from time to time.
Good luck with your Activation.
Jaime Rosales D.
