EPPlus Version-7.2.0.0 not found
DOLAPO836
DOLAPO836
An error occurred while exporting data: Could not load file or assembly 'EPPlus, Version=7.2.0.0, Culture=neutral, PublicKeyToken=ea159fdaa78159a1' or one of its dependencies. The system cannot find the file specified.
at RevitPluginArch.Helpers.ExcelExporterSingle.ExportToExcel(List`1 data, String filePath)
at RevitPluginArch.ViewModel.Blockwork.ResultViewModel.ExportToExcel()
reylorente1
Open your program, go into dependencies, search in package, right click and you will find the path (Open Folder .... ) double-click, find the lib folder, find the net.8.0 folder, open it, and the dll appears, copy it and put it in the Debug, of your script.
(Abre tu programa, entra en dependencias, busca en paquete, da click derecho y encontrara la ruta (Open Folder ....) dale dobleclick, busca la carpeta lib ,busca la carpeta net.8.0, lo abre, y aparece el dll, lo copia y lo pones en el Debug, de tu script)Captura de pantalla 2024-11-17 231817.pngCaptura de pantalla 2024-11-17 231830.png
DOLAPO836
 My project doesn't have dependencies this is my project structure
DOLAPO836
 Same issue with Google sheet also
reylorente1
I have Revit 2025, so I provided you with the answer above.
I downloaded the package and it was installed in this path:
C:Usersxxx.nugetpackagesepplus7.2.2libnet8.0.
From there I copied the dll and the html, and copied it
Opening the path from my scripts.
(Yo tengo Revit 2025, por eso te proporcione la respuesta anterior.
Yo descargue el paquete y se me instalo en esta ruta:
C:\Users\xxx\.nuget\packages\epplus\7.2.2\lib\net8.0.
De ahi copie el dll y el html, y, lo copie
abriendo la ruta desde mis scripts.
)Por aqui yo abro mi scriptsPor aqui yo abro mi scripts
scgq425
Hi @DOLAPO836 :
this error like the dll cant resolve .
in  MaterialDesignThemes also has this problem , so you can use this issue to solve this .
Not Able to use MaterialDesignThemes -Version 5.1.0 in Revit DLL
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
jackmrdoctor
you can switch to OPEN XML SDK. It's easier. i have same problem and give up using it.
