Enum BuiltInParameter - Built in parameter for inner radius, left radius and right radius is it possible to retrieve values?
Hi!
I am working in one addin in c# and i need to retrieve the value of the angles (inner radius, left radius and right radius).
So far i believe that the builtInParameter in revit API is not returning those values.
Does anyone know if i am right, or if there is one way to get those values?
jeremy_tammik
These look like family parameters to me, not shared parameters.
However, you can retrieve both using the Revit API.
Please explore your family instance element and possibly it associated element type using RevitLookup to determine where this data can be found and how to access it programmatically.
Thank you! So, that was what i was thinking. I already retrieve the shared parameters, i need to retrieve the one who are not shared like inner radius p.e of a curve.
I used RevitLookup what was helpfull and i am  thinking in using the FabricationPart class , getDimensions() to retrieve the inner radius but i still don't know if that it will work.
