Embedded Ribbon Panel Image
Mark.Ackerley
Message 1 of 8
Mark.Ackerley
Hi all,
Really sorry, but I can't get this to work.  I am sure it's really basic.  I'm just starting to learn C#
Following on from here...
https://forums.autodesk.com/t5/revit-api-forum/ribbon-panel-button-image-from-embedded-resource/m-p/...
I have an embedded resource .png which I cannot get to link into my  project correctly.
This is obviously wrong...
PNGtoImageSource("HTA_Ribbon.totalLength.png");
Any assistance greatfully received.
Apologies again for such a basic question.
Mark
Code below
using System;
using System.Reflection;
using System.IO;
using Autodesk.Revit.UI;
using System.Windows.Media;
using System.Windows.Media.Imaging;
namespace HTA_Ribbon
    class App : IExternalApplication
        private ImageSource PNGtoImageSource(string embeddedPath)
            Stream myStream = Assembly.GetExecutingAssembly().GetManifestResourceStream(embeddedPath);
            PngBitmapDecoder decoder = new PngBitmapDecoder(myStream, BitmapCreateOptions.PreservePixelFormat, BitmapCacheOption.Default);
            return decoder.Frames[0];
            // define a method that will create our tab and button
            static void AddRibbonPanel(UIControlledApplication application)
            // Create a custom ribbon tab
            String tabName = "HTA";
            application.CreateRibbonTab(tabName);
            // Add a new ribbon panel
            RibbonPanel ribbonPanel = application.CreateRibbonPanel(tabName, "Tools");
            // Get dll assembly path
            string thisAssemblyPath = System.Reflection.Assembly.GetExecutingAssembly().Location;
            // create push button for CurveTotalLength
            PushButtonData b1Data = new PushButtonData(
                "cmdCurveTotalLength",
                "Total" + System.Environment.NewLine + "  Length  ",
                thisAssemblyPath,
                "Curve_Total_Length.CurveTotalLength");
            //add push button to ribbon
            PushButton pb1 = ribbonPanel.AddItem(b1Data) as PushButton;
            pb1.ToolTip = "Select Multiple Lines to Obtain Total Length";
            // create embedded Large Image
            BitmapImage pbImage = PNGtoImageSource("HTA_Ribbon.totalLength.png");
            pb1.LargeImage = pbImage;
        public Result OnShutdown(UIControlledApplication application)
            // do nothing
            return Result.Succeeded;
        public Result OnStartup(UIControlledApplication application)
            // call our method that will load up our toolbar
            AddRibbonPanel(application);
Replies (7)
Message 2 of 8
BenoitE&A
Have you tried the internet ?
https://stackoverflow.com/questions/6503424/how-to-programmatically-set-the-image-source/6503445
I think it is the syntax we used, and it workks...
Benoit FAVRE
CEO of etudes & automates
www.etudesetautomates.com/
Message 3 of 8
Mark.Ackerley
Thank you for the reply 🙂
Yes the tutorial I was following used a uri but it was failing in 2019, the message said it failed to load 😞
http://archi-lab.net/create-your-own-tab-and-buttons-in-revit/
In the previously referenced post, Jeremy said embedded was better and I tried using the code supplied, but it isn’t working.
I did lots of googling but can’t get it to work.
All suggestions welcomed 😄
Mark
Message 4 of 8
BenoitE&A
Hey,
We sell a ribbon and we definitely use an URI like this
BitmapImage BT_img = new BitmapImage(new Uri(iconPath + "LogIn.bmp"));
And it works with 2019.
Benoit
Benoit FAVRE
Message 5 of 8
BenoitE&A
The bottom of it is : you say you have a problem with a function (ImageToPNG() or something like this) and you don't provide the code for this. Since this function is not natural C# we don't know what it's for, and we can't help you !
But anyway the URI way works, so you have at least one solution...
Benoit FAVRE
Message 6 of 8
Mark.Ackerley
Thanks for the response.
As I understand it, the code for the function is at the top?
I didn’t post the code for the linked file because it isn’t the preferred solution. But I can recreate it and post it when I’m back in the office.
I would prefer to embed the image if possible.
Mark
Message 7 of 8
BenoitE&A
Hi again,
Sorry had not seen your method, I don't use it but it looks ok.
Then I don't know what actually does not work. Here are some ideas :
- check first that the path and the name of the image are correct
- then there is the stuff about the dpi of the image, which is an old problem that Autodesk has not fixed :
https://thebuildingcoder.typepad.com/blog/2010/09/ribbon-icon-resolution.html
Benoit
Benoit FAVRE
Message 8 of 8
Mark.Ackerley
Thanks for getting back to me.
It seems my use of "_" in the NameSpace was upsetting it.
I presume it's how the URI works... I guess it's conversion of symbols to a path was being messed up.
It also failed with "-" in the image name.
All is well 😄
Thanks again,
Mark
