elements event
elements event
elements event
I need acquire event of elements .For example, picked or double-click with a wall, when I need access the member function. But,there are no picked or double-click events in the Revit API. What should I do.
xiaosz
Dear xiaosz,
you can write triggers for element modification/Addition/Deletion. you cannot find double click event on element .
Please see this post for DMU(Dynamic Model Updater). and you can also find more using DMU you can write triggers on element event.
http://thebuildingcoder.typepad.com/blog/2010/08/structural-dynamic-model-update-sample.html
Dear BholaDev,
Think you very much.
I can't access the URL. http://thebuildingcoder.typepad.com/blog/2010/08/s​tructural-dynamic-model-update-sample.html
Can you help me copy in this post.
another question, Can I find double click event in revit application or document.
Dear,
i think no you can find document change event.
Following are document events. You can check in apps while writing codDocumentEvent.pnge.
Entire code for DMU example but better you read post from given link.
[Transaction( TransactionMode.Automatic )]
[Regeneration( RegenerationOption.Manual )]
public class AlignRebar : IExternalApplication
  /// <summary>
  /// On shutdown, unregister the updater
  /// </summary>
  public Result OnShutdown( UIControlledApplication a )
    RebarUpdater updater
      = new RebarUpdater( a.ActiveAddInId );
    UpdaterRegistry.UnregisterUpdater(
      updater.GetUpdaterId() );
    return Result.Succeeded;
  /// <summary>
  /// On start up, add UI buttons, register
  /// the updater and add triggers
  /// </summary>
  public Result OnStartup( UIControlledApplication a )
    // Add the UI buttons on start up
    AddButtons( a );
    RebarUpdater updater = new RebarUpdater(
      a.ActiveAddInId );
    // Register the updater in the singleton
    // UpdateRegistry class
    UpdaterRegistry.RegisterUpdater( updater );
    // Set the filter; in this case we
    // shall work with beams specifically
    ElementCategoryFilter filter
      = new ElementCategoryFilter(
        BuiltInCategory.OST_StructuralFraming );
    // Add trigger
    UpdaterRegistry.AddTrigger(
      updater.GetUpdaterId(), filter,
      Element.GetChangeTypeGeometry() );
  /// <summary>
  /// Add UI buttons
  /// </summary>
  public void AddButtons( UIControlledApplication a )
    // create a ribbon panel on the Analyze tab
    RibbonPanel panel = a.CreateRibbonPanel(
      Tab.Analyze, "RST Labs" );
    AddDmuCommandButtons( panel );
  /// <summary>
  /// Control buttons for the Dynamic Model Update
  /// </summary>
  public void AddDmuCommandButtons(
    RibbonPanel panel )
    string path = GetType().Assembly.Location;
    string sDirectory
      = System.IO.Path.GetDirectoryName( path );
    // create toggle buttons for radio button group
    ToggleButtonData toggleButtonData3
      = new ToggleButtonData(
        "RSTLabsDMUOff", "Align Off", path,
        "RstAvfDmu.UIDynamicModelUpdateOff" );
    toggleButtonData3.LargeImage
      = new BitmapImage( new Uri( sDirectory
        + "\\Images\\" + "Families.ico" ) );
    ToggleButtonData toggleButtonData4
        "RSTLabsDMUOn", "Align On", path,
        "RstAvfDmu.UIDynamicModelUpdateOn" );
    toggleButtonData4.LargeImage
    // make dyn update on/off radio button group
    RadioButtonGroupData radioBtnGroupData2 =
      new RadioButtonGroupData( "RebarAlign" );
    RadioButtonGroup radioBtnGroup2
      = panel.AddItem( radioBtnGroupData2 )
        as RadioButtonGroup;
    radioBtnGroup2.AddItem( toggleButtonData3 );
    radioBtnGroup2.AddItem( toggleButtonData4 );
public class RebarUpdater : IUpdater
  public static bool m_updateActive = false;
  AddInId addinID = null;
  UpdaterId updaterID = null;
  public RebarUpdater( AddInId id )
    addinID = id;
    // UpdaterId that is used to register and
    // unregister updaters and triggers
    updaterID = new UpdaterId( addinID, new Guid(
      "63CDBB88-5CC4-4ac3-AD24-52DD435AAB25" ) );
  /// <summary>
  /// Align rebar to updated beam
  /// </summary>
  public void Execute( UpdaterData data )
    if( m_updateActive == false ) { return; }
    // Get access to document object
    Document doc = data.GetDocument();
    try
      // Loop through all the modified elements
      foreach( ElementId id in
        data.GetModifiedElementIds() )
        FamilyInstance beam = doc.get_Element( id )
          as FamilyInstance;
        // Create a filter to retrieve all rebars
        FilteredElementCollector rebars
          = new FilteredElementCollector( doc );
        rebars.OfCategory( BuiltInCategory.OST_Rebar );
        rebars.OfClass( typeof( Rebar ) );
        foreach( Rebar rebar in rebars )
          // Calculate the beam line
          XYZ beamStartPoint = new XYZ();
          XYZ beamEndPoint = new XYZ();
          Line line = CalculateBeamLine( beam );
          // Get the start and end point
          if( null != line )
            beamStartPoint = line.get_EndPoint( 0 );
            beamEndPoint = line.get_EndPoint( 1 );
          // To align the rebar to the new beam's
          // length, we split the tasks in two stages
          // Step 1: Move the rebar to align with one
          // of the end of the beam
          // For this we first access the
          // rebar line geometry
          Line rebarLine = rebar.Curves.get_Item( 0 )
            as Line;
          // Calculate the translation vector
          // (the extent of the move)
          XYZ transVec = new XYZ( beamStartPoint.X
            - rebarLine.get_EndPoint( 0 ).X, 0.0, 0.0 );
          // Perform the move
          doc.Move( rebar, transVec );
          // This move causes the beam line to change
          // and so recalculating the beam line
          // Step 2: Set the new length of the rebar
          // based on new beam length. For this, we
          // can set the relevant parameter after
          // checking at UI
          rebar.get_Parameter( "B" ).Set(
            GetLength( line ) );
    catch( Exception ex )
      TaskDialog.Show( "Exception", ex.Message );
  private Line CalculateBeamLine(
    FamilyInstance beam )
    GeometryElement geoElement
      = beam.get_Geometry( new Options() );
    if( null == geoElement
      || 0 == geoElement.Objects.Size )
      throw new Exception(
        "Can't get the geometry of selected element." );
    Line beamLine = null;
    foreach( GeometryObject geoObject
      in geoElement.Objects )
      // get the driving path and vector of the beam
      beamLine = geoObject as Line;
      if( null != beamLine )
        return beamLine;
    return null;
  /// <summary>
  /// Return the length of the given line
  /// </summary>
  public static double GetLength( Line line )
    XYZ v = line.get_EndPoint( 1 ) - line.get_EndPoint( 0 );
    return v.GetLength();
  /// <summary>
  /// Return the auxiliary string
  /// </summary>
  public string GetAdditionalInformation()
    return "Automatically align rebar to match beam";
  /// <summary>
  /// Set the priority
  /// </summary>
  public ChangePriority GetChangePriority()
    return ChangePriority.Rebar;
  /// <summary>
  /// Return the updater Id
  /// </summary>
  public UpdaterId GetUpdaterId()
    return updaterID;
  /// <summary>
  /// Return the updater name
  /// </summary>
  public string GetUpdaterName()
    return "Rebar alignment updater";
[Transaction( TransactionMode.ReadOnly )]
public class UIDynamicModelUpdateOff : IExternalCommand
  public Result Execute(
    ExternalCommandData commandData,
    ref string message,
    ElementSet elements )
    RebarUpdater.m_updateActive = false;
public class UIDynamicModelUpdateOn : IExternalCommand
    ref string message,
    RebarUpdater.m_updateActive = true;
