ElementIntersectElementFilter
Is it possible to use ElementIntersectElementFilter between Parts and Generic Models?
I'm using the code below but I keep getting 0 elements in my collector even if invert the ElementIntersectElementFilter.
UIApplication uiApp = commandData.Application;
Document doc = uiApp.ActiveUIDocument.Document;
Selection selsrc=uiApp.ActiveUIDocument.Selection;
Reference obj = selSrc.PickObject(ObjectType.Element);
Element element = doc.GetElement(obj);
FilteredElementCollector collector = new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Parts).WherePasses(new ElementIntersectsElementFilter(element));
Thank you.
jeremytammik
This is a duplicate of your previous ideantical thread:
http://forums.autodesk.com/t5/revit-api-forum/elementintersectelementfilter/m-p/6751980
Please avoid producing multiple identical threads.
Please let us continue the discussion in the other one.
Thank you!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
